Pietenpol-List: Vertical Stab
Question I am building the vertical stab, and made a mistake. After fitting all mypieces in the jig I found that I had made the junction of the bottom beam andthe tail post the opposit way that it should be. Is this a problem?ThanksNick Harris________________________________________________________________________________
Re: Pietenpol-List: Vertical Stab
Original Posted By: Nick Harris
Uhh, not sure what you mean....maybe a picture would help. I for one have onlyan idea what you might be describing here...but anyway, if it's a junction oftwo pieces that will end up with gussets on both sides of the junction (as manyon the vertical stab do), it probably won't be an issue....Jim MarklePlano, TX214.505.6101 ----- Original Message -----
Sorry for the bad description. Here is a link, I hope it works. Look at the lowerleft hand of the part. According to the plans the lower beam should joininto the tail post. I have it just the opposite.http://www.mykitplane.com/Planes/buildL ... camperNick ----- Original Message -----
RE: Pietenpol-List: Vertical Stab
I did when this pic was taken. Since then I cut it down closer to finish length.The bolt was one of my concerns also, but the front bolt bolt holes go throughthe joint also. Maybe it would be best to just make a new one. ----- Original Message -----
Nick,If you use birch plywood gussets at this joint and make the fittings slightly longerso that the bolt holes don't line up with the joint line, it should be OKas is. Birch plywood, aircraft quality, is very strong and stiff---and the primarystrength of the joint is in the gussets, not the butt joint.Just keep the bolt hole(s) away from the joint line.Graham (Pietenpol CF-AUN)________________________________________________________________________________Date: Thu, 29 Sep 2005 01:21:42 -0700
Original Posted By: "RULE, HARVEY"
Original Posted By: Lou Wither
Re: Pietenpol-List: Landing Gear Alignment
