Pietenpol-List: Who's on First?
Original Posted By: TRichmo9(at)aol.com
I'm a Piet builder in McPherson, KS looking for someone nearby who has acompleted or nearly completed Air Camper to shoot some photos of. Ihave heard that there is a very nice Piet at the Benton, KS. airport.Can someone out there tell me who to contact to see this airplane? I'dbe more than happy to buy someone lunch so I could talk his/her ear offabout my own project.Tom Stinemetze____ | ____ 8/ / ________________________________________________________________________________
Re: Pietenpol-List: Who's on First?
Original Posted By: Jdavis2a(at)wmconnect.com
Subject: Re: Pietenpol-List: Who's on First?tom there are 4 completed piets in tulsa________________________________________________________________________________
Original Posted By: "Michael Conkling"
Subject: Re: Pietenpol-List: Who's on First?I live at Collinsville,OK. Probably a 3 hr. drive but you are welcome to look, take all the pictures and talk all you want. I have a corvair powered Pietthat has been flying since 1995. You can contact me at jdavis2a(at)wmconnect.com or 918-371-9624 if you are interested. JIM BALLEW________________________________________________________________________________
Original Posted By: Tom Stinemetze
Chuck Gantzer must be sleeping in!! ;-) Tom, he's the one you want to visitwith -- he did have his Piet at Benton (till they decided to take down theold row of hangars)Mike C.Pretty Prairie, KS ----- Original Message -----
Original Posted By: Mark
RE: Pietenpol-List: Sealing wood
Subject: Re: Pietenpol-List: Who's on First?Tom, Like Mike C. said, I used to have my plane at Benton, and yes...I enjoy sleeping in !! I'm down at Cook Airfield now. It's between Derby and Rose Hill. Great little airport...not too busy, 1600 foot grass runway, and 2600 foot hard surfacerunway. I have a really good hanger now, it's all closed in, and has electric, and a concrete floor. At Benton, it was an open Tee hanger, and birdsconstantly had their way with my plane !! It would be great to get together this week sometime. I could even fly up to McPherson after work some day...weather permittiing. I flew up there andmet a guy named Chad Johnson, who was wanting to build a Piet, but haven't heard from him in quite a while. E-mail me off list, and we can arrange a meeting.Chuck GantzerNX770CG________________________________________________________________________________Subject: RE: Pietenpol-List: Sealing woodDate: Mon, 3 Oct 2005 07:52:47 -0400
Re: Pietenpol-List: Sealing wood
I found the same problem. I solved it by buying and applying the Polyfiber Epoxy with a small roller to all the fabric attach points. Istill have some of the quart kit left. I didn't bother to recoat theinside structure with it. That way I got both cheap and good.Steve E-----Original Message-----
Original Posted By: "John and Phyllis Smoyer"
Subject: Pietenpol-List: Sealing woodMark: You might also want to look at every low spot or dam that couldhold moisture including lower fus. side gussets, and drill drain holesthrew all of these "dams" Leon S.________________________________________________________________________________Date: Mon, 03 Oct 2005 19:50:48 -0400
Jim,How far is Collinsville, OK from Fort Worth, Texas? I might want to driveup and take a look. Thanks.Mike KingGN-177MKDallas ----- Original Message -----
RE: Pietenpol-List: Elevator control cable connections
Subject: Re: Pietenpol-List: Who's on First?it 259 miles tom________________________________________________________________________________Subject: RE: Pietenpol-List: Elevator control cable connectionsDate: Tue, 4 Oct 2005 11:27:49 -0400
Re: Pietenpol-List: Elevator control cable connections
Subject: Re: Pietenpol-List: Elevator control cable connectionsIf you guys insist on paying $5 ea for shackles that is sure your priv. But I will once again give you a tip given me by Joe C. Go to Home Depot, wire rope section, for Attwood stainless steel EYE STRAPS, 1/2 ". You get 2 for about$ 1.50. Bend the ears around in a vise and you have a perfect shackle, strong and light. $ 1.50 vs $10.00 plus freight. No way.________________________________________________________________________________
Original Posted By: "Mike King"
Subject: Re: Pietenpol-List: Who's on First?Collinsville is about 10 miles north of Tulsa. It takes me about 4.5 hours to go to the American Airlines training center in Fort Worth if that helps. Just give a little advanced notice. I'm available most of the time. There arethree other Piets on the field which I can probably get you a look at least acouple of them.JIM________________________________________________________________________________
Jim,Sounds good to me. We might even get Jim Markle to go alongfor the ride. I now live in Ponder......just north of the Texas Motorspeedway.It would be good to see some other planes too.Thanks Jim.Mike ----- Original Message -----
