Pietenpol-List: Re: Pietenpol-List Digest: 11 Msgs - 10/15/05
Re: Pietenpol-List: Re: Pietenpol-List Digest: 11 Msgs - 10/15/05
Subject: Re: Pietenpol-List: Re: Pietenpol-List Digest: 11 Msgs - 10/15/05
Original Posted By: Ben Williams
Creve Coeur Airport in st.louis, county is still there. It is privately owned andwill not be turned into a park although there is a Creve Coeur park nearby.I drive by there about every other week. The hangers are all there and the grassand paved runways also.Dennis ----- Original Message -----
Re: Pietenpol-List: Elmer's Ultimate Glue?
Original Posted By: Jim Ash
Subject: Re: Pietenpol-List: Elmer's Ultimate Glue?In a message dated 10/17/2005 3:03:02 PM Central Standard Time, benw(at)pdi.com writes:Gentlemen,First time writing to this list.I'm building wing ribs using Elmer's Ultimate polyurethane glue.I'm using Douglas Fir and aircraft plywood. After assembly, all wood will be covered with West System epoxy.http://www.westsystem.com/Will this work or should I trash these ribs and use a different glue?Thanks,Ben WilliamsBen, Personally, I use what is well proven, hence I use T88 exclusively. I would NOT trust my life to an experiment with Elmer's Ultimate Polyurethane glue. Nor could I sell a project with that glue, with a clear mind. I say use the ribs you built as an experience to learn how to build your actual ribs, using T88. You could also use several of them for destructive tests, or for a wall hanging.Chuck GantzerNX770CGShot some video with the camera mounted on the belly, looking forward between the gear legs on Friday and Saturday. Shot some Air to Air video on Sunday !!________________________________________________________________________________Date: Mon, 17 Oct 2005 18:17:54 -0400 (GMT-04:00)
RE: Pietenpol-List: Elmer's Ultimate Glue?
Original Posted By: "Textor, Jack"
