Pietenpol-List: Glue, Model A prop bolts
Subject: Pietenpol-List: Glue, Model A prop boltsGlue-- I am using Aeropoxy because a local wood guy sells it. It worksfine and is probably identical to T-88. A couple of years ago I talkedto these guys at their booth at Oshkosh and that told me they offer aepoxy glue which is just for wood. It contains gap fillers and issuppose to be stronger if you have gaps, than regular epoxy or if youadd micro fillers to regular glue. I am continuing to use the regularstuff since that is what I started with. Also, none ofthe usualsuppliers sells it. They just sell the regular stuff. Just making sure Ihave no gaps.. Model A prop bolts-- An easy way out of the Model A propcenter bolt/axel stub hub thing is to buy the adapter from Dick Weeden(at Brodhead) that takes the four bolt flywheel flange to the six boltContinental prop hub bolt pattern. Ken Perkins also sells them, Ps Doesany one know how Ken is doing since his hospitalisation? Leon Stefan.Kansas No more building for the winter.________________________________________________________________________________Date: Tue, 25 Oct 2005 18:17:18 -0700 (PDT)
