Pietenpol-List: Grade 8 bolts
Original Posted By: harvey rule
Re: Pietenpol-List: Grade 8 bolts
27, 2005) at 12/02/2005 09:00:44 PMFollow the link for info on AN hardwarehttp://www.zenithair.com/kit-data/ra/hardware. ... __________
Original Posted By: "Mark Pilkington"
Points about threads, bending and brittleness made in this discussion are all veryvalid. I should have made one additional point earlier. All of these Grade8 bolts are replaced with each annual condition inspection. I have not seenany wear but changed anyway.I do appreciate the exchange of ideas. It makes us all safer in the end.Dick N.________________________________________________________________________________
AN specs date back to the 1920's and would have been available throughNicholas-Beazley and others.Forrest Lovely, if you are watching the list, can you shed any light on the hardwareBernard used when constructing his airplanes?Greg CardinalMinneapolis ----- Original Message -----
Subject: Pietenpol-List: Grade 8 boltsGentlemen,I bought some grade 8 bolts to hold my prop onto my engine. Does anyone think this is a bad idea? I have heard differing views on this and now I am second-guessing myself. Please weigh-in. Thanks.Dan HelsperPoplar Grove, IL.**************Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips andcalculators. (http://www.walletpop.com/?NCID=emlcntuswall00000001)________________________________________________________________________________
RE: Pietenpol-List: Grade 8 bolts
> ** Pietenpol-List: Grade 8 bolts
Subject: Pietenpol-List: Grade 8 boltsSteve,Wow- after reading that article I will not use those industrial bolts. But I checked on the Sensenich web sight and their bolts are way too much- at least $200.00 with shipping. I think I will take my chances with AN bolts. Its hard to find the right ones because the threaded length is so short. Thanks. Dan HelsperPoplar Grove, IL.**************Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips andcalculators. (http://www.walletpop.com/?NCID=emlcntuswall00000001)________________________________________________________________________________
Original Posted By: "walt"
Dan. I may be able to help out. I misordered prop bolts (3/8 AN 6) several times (wrong length) plus changed props (needed new length) and have kept them just in case. If your interested send me the length you need and I'll check the next time I go to the hanger. Gene in Tennessee ----- Original Message -----
Original Posted By: Gene & Tammy
Dan I forgot to mention that if I have the right length for you, their yours for the postage.Gene ----- Original Message -----
Original Posted By: H RULE
Subject: Re: Pietenpol-List: Grade 8 boltsGene,Thanks for the offer, but I ordered them from Spruce and they are already shipped. Darn!! Dan HelsperPoplar Grove, IL.**************Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips andcalculators. (http://www.walletpop.com/?NCID=emlcntuswall00000001)________________________________________________________________________________Date: Wed, 24 Sep 2008 15:50:51 -0700 (PDT)
> > > HelsperSew(at)aol.com wrote:> > Wow- after reading that article I will not use those> industrial bolts. > > (etc.)> Good article, and kind of scary. I can't help> wondering, though, what > the sainted Mr. P. used to keep prop and hub together. Bet> his bolts > didn't come from Sensenich. Probably weren't AN,> either, all things > considered.> > Owen> > http://www.matronics.com/Navigator?Pietenpol-List ________________________________________________________________________________
