Re: Pietenpol-List: Video Now Available: Flying NX770CG
Pietenpol-List:
Original Posted By: Dave Case
Pietenpol-List: DF weight, latex paint...
Original Posted By:> "Carl Vought"
Carl,It is Sherwin Williams. This seems to be the latex that I kept running intowhenever someone had tried it.Ted
Re: Pietenpol-List: TRANSFER PUNCHES
I just got a Harbor Freight catalog today and the Transfer Punches are on salefor $ 4.99. Dennis ________________________________________________________________________________Date: Fri, 23 Sep 2005 08:32:58 -0500
Subject: Re: Pietenpol-List: Video Now Available: Flying NX770CGIn a message dated 9/21/2005 8:01:49 AM Central Standard Time, at7000ft(at)gmail.com writes:Do you have a PayPal account Chuck?RickNo, I haven't got a PayPal account. Wouldn't even know how to set one up. That's why I figured anyone who is interested could just e-mail me directly, and send a Check, or Money Order to my home address, along with your return address, and I'll get the DVD video out in the mail to you. Like I said, thisis an ongoing project, and I thought I'd send out this Version 1 at the introductory price of $15, and get some feedback on how I might improve the video.I have lots of stuff in mind to add, but I need some input from others, because so far, I'm the only one who has ever seen the entire video !!Chuck GantzerNX770CG________________________________________________________________________________
Subject: Re: Pietenpol-List: Video Now Available: Flying NX770CGThought I read that if I requested you would send me your address so I could send you a famous La Hot check for your video. Still haven't heard from you.Corky (Still dry in NW Louisiana)________________________________________________________________________________
Pietenpol-List: Flying NX770CG
Re: Pietenpol-List: Up AND Down trim adjustment?
Subject: Re: Pietenpol-List: Up AND Down trim adjustment?I don't have any mechanism to control the flippers for pitch trim. I use the Power Setting. I've got the C of G maintained in the envelope throughout the weight ranges, and simply pitch trim with Power. On some occasions, when the sun wouldn't wait up for me, I've had to add full power to get back to the airport before dusk, and had to hold forward stick. In order to adjust pitch trim to attain a different speed, I adjust the leading edge of the stabilizer with the turnbuckles. I've done it several times, and it is effective. However, I do have fixed trim tabs on the trailing edge of each flipper, angleddown, holding the flipper up.Chuck G.NX770CG________________________________________________________________________________Date: Wed, 7 Dec 2005 18:32:16 +0000 (GMT)
Re: Pietenpol-List: bolts
Original Posted By:> santiago morete
>Up here in cold Canada they just lay around on the ground and we pick up whatever we need and install em.Sometimes ya have ta throw em down again if ya pickup the wrong one.This time of year they get awfully cold to the touch.If youuse wet hands then you have to go inside till the bolt falls off again.It canbe painful sometimes!
Re: Pietenpol-List: Flying NX770CG
> To: "pietenpol-list(at)matronics.com" > Subject: Pietenpol-List: bolts> > Regarding bolts types, we use (in Argentina) 8.8 metric bolts, which I think,is the equivalent to a grade 5. This is recommended here, in Spain by the AAE(Spanish EAA) and widely used in Europe. Of course, AN bolts are imported hereand very expensive, but easily available for you in U.S.A and cheap. > 8.8 bolts are absolutely safe for our purpose. Saludos> > Santiago Morete> > > ---------------------------------> 1GB gratis, Antivirus y Antispam> Abr tu cuenta aqu> ________________________________________________________________________________Date: Wed, 07 Dec 2005 15:59:54 -0500
