Pietenpol-List: Wing Build Question
I've been gawking at Hoopman Wing Plan (WP) Drawing (3/3/34), the Full Size RibPlan and the 3 Piece Wing Supplement drawing (1/10/75 revised 3/13/82) and needa little help before I build my rib jig and start cranking out garbage.Full size rib plan shows vertical braces in the ribs one behind the front sparand one ahead of the rear spar. 3/3/34 WP drawing doesn't show these. Thesevertical braces seem like they definitely should be there for strength and alignmentreasons, right?Full Size Rib Plan shows a slot for a tongue in the trailing edge. Do you haveto create your own TE stock? Didn't see it on Aircraft Spruce site, but it mightbe called something else and I'm looking in the wrong place.Original WP drawing (3/3/34) shows a 1" x 4.75" spar routed down to 1/2" in certainareas. 3 Piece Wing Supp. shows a dimension of 3/4" for thickness for sparsand the same routed areas but no dimension on the thickness in the routedarea. (Still maintain a 1/2" thickness inside routed area and remove 1/8" fromeach side?) Did Mr. Pietenpol determine that 1" was overkill? 3/4" just seemsa little light. Again, I will now take the lead for the least advanced questions posted on thelist ...if your rib jig has clamps that hold the gussets in place while the T-88sets, do you even need nails? I would think that 99.9% of the strength wouldcome from the adhesive. I plan to use a custom clamp arrangement using lightsprings to distribute the pressure without starving the joint.Thanks,Glenn Thomas________________________________________________________________________________
Re: Pietenpol-List: Wing Build Question
Original Posted By: Glenn Thomas
GlennI started out stapling all gussetts to the ribs and removing later. I later foundthat was really not needed. With T-88, simply pressing into place was fine.I made my trailing edge stock by sawing down pieces of Douglas Fir from the lumberyard. It is stronger than Sitca, but heavier. There is some high quality stockavailable used for flooring. There is also aluminum TE stock in the ACScataloug, if you want to go that way.I made mine by the method on the full size plan, I have seen it both ways. Thewing is so over built it really doesn't make a structural difference. Paul Poberenzybuilt a Piet wing with 1/4x1/4 ribs.Dick N. ----- Original Message -----
Original Posted By: "Kirk Huizenga"
RE: Pietenpol-List: Wing Build Question
Original Posted By: "Hodgson, Mark O"
