Routed Spars ? Bird Flue affecting the commercial airliners(Embedded image moved to file: pic00912.gif)[]________________________________________________________________________________
RE: Pietenpol-List: Re: wing spar
Re: Pietenpol-List: hvlp sprayers
Hey,I'm getting ready to start spraying dope and am looking at the hvlp systems becausethey use less material.I am wondering if the extra heat the turbine produces will cause problems withcooking off the thinner in the dope.also, it seems like there are hvlp guns that use a regular compressor instead ofa turbine, which would then not be a problem???D________________________________________________________________________________Subject: Re: Pietenpol-List: hvlp sprayers
Original Posted By: "Michael Turrell"
Douwe,I used a turbine HVLP system for spraying Poly-Fiber covering system.There is a temperature increase which will have the thinners evaporatequicker and leaving a dull(er) finish. (poly-fiber is not glossy to beginwith)Recommend you extend to air hose with at least an additional 12 - 20 feet.This will give the air time to cool plus you have more reach.Hans "Douwe Blumberg" To Sent by: "pietenpolgroup" owner-pietenpol-l ist-server@matron cc ics.com Subject Pietenpol-List: hvlp sprayers 01/20/2006 02:24 PM Please respond to pietenpol-list@ma tronics.com Hey,I'm getting ready to start spraying dope and am looking at the hvlp systemsbecause they use less material.I am wondering if the extra heat the turbine produces will cause problemswith cooking off the thinner in the dope.also, it seems like there are hvlp guns that use a regular compressorinstead of a turbine, which would then not be a problem???D________________________________________________________________________________
Pietenpol-List: Re: hvlp sprayers
Hey,I'm getting ready to start spraying dope and am looking at the hvlp systems becausethey use less material.I am wondering if the extra heat the turbine produces will cause problems withcooking off the thinner in the dope.also, it seems like there are hvlp guns that use a regular compressor instead ofa turbine, which would then not be a problemI have both and if you already have a compressor I would go with the hvlp spraygun as it is cheaper and works better than my turbine sprayer but then I onlyspent a couple hundred dollars for mine and a real good one will set you back$500 and up .My HVLP spray gun is a gravity feed unit and It does indeed savea ton of material compared to when I used a regular high pressure gun.I thinkit is worth getting a good name ,devilbiss or similar because if you buy someof the cheap ones you will find there is not much to them and rust becomes yourfirst clue that all is not right and setting a spray pattern that you wantis another.As to the heat from the turbine it would not be an issue as your fluid comes outof a suction feed gun and does not come near any heat produced by the turbine.Hope this helps.Regards,Mike________________________________________________________________________________
