Original Posted By: "Doyle Combs"
Howdy, Pieters;Question came up over on the KRNet about how long to let paint cure before applying graphics such as N-numbers and striping. I'm sure it varies depending on the paint used; this one was a paint used on boats (International Paint Inc "Interlux #4359 White" polyurethane single part enamel). Any ideas?Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
Pietenpol-List: paint and graphics
Pietenpol-List:
This not an article for purists, but for someone looking for a project to get backin the in a relative short amount of time. I have a PGN-2 that has the bestof the GN-1 and the Piet put together in a unique way. Anyway, I had a hardlanding and have decided to sell the Piet. In all that have looked at it, it isagreed that it is repairable. I have the rib jig that came with the plane. Ihave all the plans and records that have been with the plane from the beginningof the building. The engine is a subaru E81. The prop was busted, but the lickseemed to have been absorbed by the reducer that has a back bent plate. Itis a 1.84 ratio. There is some damage to the right wing. Left wing is ok. Somedamage to landing gear and fuselage. Tailfeathers are ok. Price of $1500 includesinstruments, wheels, brakes, engine and reducer. The only think to buyis a prop. I will consider selling it without instruments or wheels and brakes.If you would like to see pictures, email me offline. I remember the fuss whenthe net gets loaded with pictures. I will email photos of the project.Doyle CombsP. O. Box 421Lometa, Texas 76853512-752-9202________________________________________________________________________________Date: Sat, 4 Feb 2006 18:19:13 -0800 (PST)
Re: Pietenpol-List: fuel tank sealer.
My fuel tank is welded, but I added the sealant anyway. When I built that tankI fabricated, rivited it together then took it to a welder. He welded over therivits and seams. When I pressure tested it there were a few pinhole leaks,which he repaired, but that drove me to use sealer. At the time, I figured itwould give some added protection against leaks. I will be keeping watch onthe condition of the tank and if necessary, replace it. I have to make two moretanks for my new project anyway. I have an expanded center section on theproject, with 32" wide space for fuel (18 gal cap) and seperate tanks gives addedsafety.Dick N. ----- Original Message -----
Re: Pietenpol-List: evening
Subject: Re: Pietenpol-List: eveningid love to see those pics tom ________________________________________________________________________________
I would also like to see Ben's Dad's Aircamper...Hey Ben, if you wouldn't mind sending them offline, I have broadband so send em'on!ThanksJim in Plano TX.....just bolted all the control hardware and fittings into thepilot and passenger area, made the cables for the passenger rudder pedals, boltedon all the engine mount fittings....put cotter pins in where they belong...________________________________________________________________________________Date: Sat, 04 Feb 2006 21:29:06 -0800
