Pietenpol-List: Drill Bits
Original Posted By: "Catdesign"
What style of AN3-17 do we use on the lower cabaine fittings? Drilled shank witha castle nut or use a nyloc nut or just a plane old nut and washer? Whenis it ok to use non-drilled bolts and when should you use drilled (for safetywire)? I know I should know this but I don't know this, ya know what I mean?Chris TracySacramento, CaRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Drill Bits
What style of drill bits are people using to drill through the wood. Twist? BradPoint? Are you drilling the correct size hole first or sneaking up on it withincreasingly larger bits?Chris TracySacramento, CaRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 23 Mar 2006 05:44:46 -0500
Pietenpol-List: Drilled Bolts or Not
