Re: Pietenpol-List: Clif Dawson's handle wraps
Pietenpol-List: Re: Clif Dawson's handle wraps
Original Posted By: "Kenneth M. Heide"
Clif,I would be interested in that information. I like the your wraps too!!Great work!!--------Brent O.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 6 Apr 2006 10:49:49 -0700 (PDT)
Re: Pietenpol-List: Carb issues for the corvair
Original Posted By: harvey rule
Ken,This quote from William Wynne's site:-There are four different carburetors that dominate the field of flyingCorvairs. These are divided among two applications: gravity feed fuelsystems (most high wing airplanes and low wing airplanes with header tanks)and pressure fuel systems (mostly seen in low wing airplanes without headertanks). If you are using a gravity feed fuel system, you can use any of thefour popular carburetors. These carbs are the Ellison EFS-3A, MarvelSchebler MA3-SPA, Stromberg NAS-3, and Monnett Aero-Carb. If you have apressure fuel system, like a 601XL or a KR-2 without a header tank, thenyou should be using an EFS-3A or an MA3-SPA. The Corvair runs well on allof these carbs. Bill Clapp's KR-2S has nearly 300 hours on an Aero-Carb.Mark Langford's and Steve Makish's KRs both run on Ellison EFS-3As. DaveThe Bear's Wagabond and the Skycoupe both fly on Strombergs. Our 601 andthe Cleanex both have MA3s.Ellison Fluid Systems sells the EFS-3A. And the Monnett family is the onlyplace to get an Aero-Carb. Either of these carbs fit on a single model ofour CNC stainless intake manifold. Alternatively, the Stromberg and MA3both fit on a slightly different manifold we make. All of the carburetorsexcept the MA3 require a primer. We weld a single primer port in the uptube on the right hand side of the intake manifold. This is common practiceon certified engines. The MA3-SPA's accelerator pump makes a primerunnecessary.-My comments:All of the above are either hard to find or expensive (or both).I choose to go with a Zenith Carburetor as used on the larger VWconversions.You can buy them at: http://www.greatplainsas.com/sccarb.htmlThey call them 1821 carburetors after the VW engine conversion theyrepresent.The Zenith designation is # 267 see at:http://www.zenithfuelsystems.com/updraft_267.htmIt gives me about 2800 RPM static and about 3000 WOT flyingAlthough I fly most of the time at about 70 Mph which is less than 1/4throttle (2200 RPM)I did remove the choke, have a primer on the LH intake manifold a homemade carb heat box.Hans "Kenneth M. Heide" Pietenpol Sent by: owner-pietenpol-l cc ist-server@matron ics.com Subject Pietenpol-List: Carb issues for the corvair 04/06/2006 12:49 PM Please respond to pietenpol-list@ma tronics.com Fellow Pieter's:I am interested to hear what carburetors are use on the corvair conversion.It appears the NA-S3B Stromberg has been mention but having difficultiesfinding a good one even on E-Bay. Are there other carbs being utilized moreoften than others? Just looking for answers before I start my search....Ken H.Fargo, NDrates.________________________________________________________________________________Date: Thu, 06 Apr 2006 14:49:10 -0400
Clif,Could you post those pages or email them to me. I'd like to see how they're done.Thanks!--------Glenn ThomasN?????http://www.flyingwood.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 07 Apr 2006 14:59:35 -0400
Original Posted By: Kenneth M. Heide
I have an NAS-3A1 on mine. works GREAT! I get about 2950 static with my 66x29propDJ ----- Original Message -----
forgot to mention I had an AeroCarb and hated it. It stuck often and leaked fuel. ----- Original Message -----
Original Posted By: "Kirk Huizenga"
RE: Pietenpol-List: Experimental Certification Kit from EAA
