Pietenpol-List: tire pressure
For you folks NOT running skinny tires... 41CC has 6.00x6 tires... what kind of pressure do you run in them? The tire charts are all over the place, depending on number of plies and so forth, but looks like for a gross weight in the 1100 lb. range, something like 25-30 psi. Sounds high to me which is why I'm asking the question.So, who is running what tire pressure in non-motorcycle tires, Cub style gear? Thanks!Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Date: Mon, 17 Apr 2006 12:51:54 -0500
Re: Pietenpol-List: tire pressure
Original Posted By: "Catdesign"
Subject: Re: Pietenpol-List: tire pressureIn a message dated 4/17/2006 11:54:26 AM Central Standard Time, taildrags(at)hotmail.com writes:So, who is running what tire pressure in non-motorcycle tires, Cub style gear?I have Carlisle, Tube Type 8.00 - 6 Turf Tires from Wicks ($30 each), and they list max inflation at 20 psi. I keep them at about 15 psi.Chuck G.NX770CG________________________________________________________________________________
