Original Posted By: "Dan Loegering"
Pietenpol-List: Wing rib jig
Re: Pietenpol-List: Wing rib jig
Original Posted By: "jimboyer(at)hughes.net"
Subject: Re: Pietenpol-List: Wing rib jigA thought came to my ole mind the other night as I lay awake Piet dreaming. I doubt this has ever happened to you!!!!IF I were to ever build another rib jig I would use 3/4 plywood at least 18 in X 72 in. Use scrap capstrip nailed as a guide for your router. With a 1/4 in bit, rout your cap strip positions about 3/8 in deep. Talk about accuracy and uniformity. I think it would be better than those surface cams and blocks.________________________________________________________________________________Date: Thu, 20 Apr 2006 15:06:34 +0000 (UTC)
