Pietenpol-List: ELT and booster seats
Yes indeed, the ELT in 41CC went off when it nosed over. No emergency response that I know of, not even a phone call, and we tested the ELT to see if the signal was going out... it was, even a day after the event and the ELT going all that time. Of course, after the first 4 to 6 hours the airplane was inside a metal hangar so little or no signal would have gone out, but it did trigger and transmit. And Mike, pay attention: in accordance with the FARs, since the ELT went off, I have now replaced the battery on the unit with a new one. Good for 24 more months or the next event that triggers it, whichever comes first ;o)Second part of my post has to do with booster seats for small passengers. Seeing the picture of Don's airplane with youngsters all over it reminded me that I need to prepare something for our 5-year-old grandson's first airplane ride in 41CC. He is just about the same size as the lad in the front cockpit of Don's Piet so I figure I'll make something with about 4" of lift that secures in the front 'pit with Velcro the same as the present front seat (upholstered piece of 1/4" ply). I'll use several layers of very firm foam as a build-up, then a cushy top layer and naugahyde over that, with a piece of ply as the base of course. While it is possible for a short passenger to see out the sides without a booster, it would be better if they could sit a bit higher and I believe the shoulder strap would be more effective that way too. Anybody else have any experience with booster seats or cushions?Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Date: Tue, 25 Apr 2006 08:01:47 -0400
RE: Pietenpol-List: Pitch trimming
Re: Pietenpol-List: Pitch trimming
Original Posted By: Jim Ash
Subject: Re: Pietenpol-List: Pitch trimmingJeff,Had the same experience with 41CC in the beginning. Forward 16 gal fuel tank, 22lb metal prop and a 140 lb test pilot. When he released the stick it nosedived. We twixed the hor stab, ( eyeballed it so it lined up with lower edge of engine rocker covers). That helped some. I Africanized a trim tab. Took a flat rubber hold down strap about a foot long. Anchored both ends to front of seat so it was just loose when wrapped around the bottom of the stick. As rear pressure was needed merely slide the rubber strap up the stick until everything equalized. If you forget to lower the strap on landing don't worryas you can override it's pressure. It is a way of solving your little problem. Another solution is have your pilot eat more Louisiana Crawfish.________________________________________________________________________________Date: Tue, 25 Apr 2006 08:50:56 -0400 (GMT-04:00)
