Pietenpol-List: Ford Model B with chevy Head
Hi EverybodyI was down at the local hardware store in Ontario Oregon and the local antique motor club had a display of old motors running.One was a ford model B with a 41 chevy head mounted via an aluminium adapter plate about 1" thick.The man claimed about 100 HP with twin stomberg 93 carbs and about 7:1 compression ratio. There was also an adapter to convert the chevy head back to the "late" model 1934 V8 waterpump. He was going to put it a car.I took some pictures of each side and could post them if anybody would like to see them.You just never know what you will see each day.Best regardsSteve G________________________________________________________________________________
Hi LeonPlease find attached two pictures of the motor.Best regardsSteve Glass>From: "Steve Glass" >Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: Ford Model B with chevy Head>Date: Sat, 29 Apr 2006 15:38:27 -0400>>>Hi Everybody>>I was down at the local hardware store in Ontario Oregon and the local >antique motor club had a display of old motors running.>>One was a ford model B with a 41 chevy head mounted via an aluminium >adapter plate about 1" thick.>>The man claimed about 100 HP with twin stomberg 93 carbs and about 7:1 >compression ratio. There was also an adapter to convert the chevy head >back to the "late" model 1934 V8 waterpump. He was going to put it a car.>>I took some pictures of each side and could post them if anybody would like >to see them.>>You just never know what you will see each day.>>Best regards>Steve G>>>http://www.matronics.com/Navigator?Piet ... ______Date: Sun, 30 Apr 2006 16:40:24 -0400
Original Posted By: "Steve Glass"
Hi LeonPlease find attached two pictures of the motor.Best regardsSteve Glass>From: "Steve Glass" >Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: Ford Model B with chevy Head>Date: Sat, 29 Apr 2006 15:38:27 -0400>>>Hi Everybody>>I was down at the local hardware store in Ontario Oregon and the local >antique motor club had a display of old motors running.>>One was a ford model B with a 41 chevy head mounted via an aluminium >adapter plate about 1" thick.>>The man claimed about 100 HP with twin stomberg 93 carbs and about 7:1 >compression ratio. There was also an adapter to convert the chevy head >back to the "late" model 1934 V8 waterpump. He was going to put it a car.>>I took some pictures of each side and could post them if anybody would like >to see them.>>You just never know what you will see each day.>>Best regards>Steve G>>>http://www.matronics.com/Navigator?Piet ... __________
