Subject: Pietenpol-List: Source for A-75 .020" under bearings?Hi Folks,Anybody know where I can buy .020" under bearings for the A-75? I tore it downthe other day due to: 1. low oil pressure (27 psi @ 145F on a 90F day with SAE 50wt) 2. no logs on the engine, hence an unknown # of hours on it3. a low frequency vibration at reduced throttle settings (about 2000 rpm downto about 1600). I found the center and rear mains worn down to the copper around 90% of their diameter,and the rod bearings showing copper under the beam of the rod. Cam andtappets look great
Original Posted By: Wizzard187(at)aol.com
.The engine had new oil pump gears and a fresh top-end w/ chrome cylinders 65 hrago when it was installed in the Piet by the builder, but I was always concernedabout the bottom end due to the lack of documentation. The vibration convincedme it was time to open & inspect.The crank passed magnaflux, but was previously ground .010" under and is now worn/scoredslighly/just out of spec for fresh .010" bearings. I haven't startedlooking for .020" under bearings as I didn't think they existed, but read ofthem tonight on Harry Fenton's website. I appreciate any "tribal knowledge" on this, as I've been into many engines ofmany types in the past but this is my first Continental. I do have the factorymanual for reference, and I have to say this is one of the simplest little engines(in a good way!) that I've ever seen. What do y'all recommend for sealing the case halves? I've always used Hylomarfor Porsche/VW engines, but this Continental appeared to have been sealed previouslywith blue Aviation Permatex.Thanks in advance!Dave MordecaiPanacea, FL, where it's too hot to fly this time of year anyway, so I may as welloverhaul my engine!Hi Folks,Anybody know where I can buy .020" under bearings for the A-75? I toreit down the other day due to: 1. low oil pressure (27 psi @ 145F on a 90F day with SAE 50wt) 2. no logs on the engine, hence an unknown # of hours on it3. a low frequency vibration at reduced throttle settings (about 2000 rpmdown to about 1600). I found the center and rear mains worn down to the copper around 90% of theirdiameter, and the rod bearings showing copper under the beam of the rod. Camand tappets look great
.The engine had new oil pump gears and a fresh top-end w/ chrome cylinders 65hr ago when it was installed in the Piet by the builder, but I was alwaysconcerned about the bottom end due to the lack of documentation. The vibrationconvinced me it was time to open & inspect.The crank passed magnaflux, but was previously ground .010" under and isnow worn/scored slighly/just out of spec for fresh .010" bearings. I haven'tstarted looking for .020" under bearings as I didn't think they existed,but read of them tonight on Harry Fenton's website. I appreciate any "tribal knowledge" on this, as I've been into manyengines of many types in the past but this is my first Continental. I do havethe factory manual for reference, and I have to say this is one of the simplestlittle engines (in a good way!) that I've ever seen. What do y'all recommend for sealing the case halves? I've always usedHylomar for Porsche/VW engines, but this Continental appeared to have been sealedpreviously with blue Aviation Permatex.Thanks in advance!Dave MordecaiPanacea, FL, where it's too hot to fly this time of year anyway, so I may aswell overhaul my engine!________________________________________________________________________________
Re: Pietenpol-List: Source for A-75 .020" under bearings?
Subject: Re: Pietenpol-List: Source for A-75 .020" under bearings?If you get Trade a plane and look for Captain Woody under cont engine parts he has .020 bearings. They are not cheap and the front main is alittle different than the orginals so you must modify the case just alittle. I madea tool to do it with. which I can bring to Broadhead.Ken Conrad in Long Grove Iowa.________________________________________________________________________________
