Pietenpol-List: Continental A-65/75 valve guide question
Subject: Pietenpol-List: Continental A-65/75 valve guide questionContinental Engine Guru's,My re-print of the Continental engine manual does not give the O.D. of the originalstandard size valve guides. The ones in the engine range from .530 to .550O.D, but I figure they've all been replaced at least a time or two (or three,or four). So, I don't know if I need .010" over, .020" over, or some otherlarger guide I can cut down to size.Anybody know the O.D. of standard size valve guides in an A-65/75?Thanks in advance,Dave MordecaiPanacea, FLwhere NX520SF patiently awaits her crankshaft to return from Rick Roman's.....Continental Engine Guru's, My re-print of the Continental engine manual does not give the O.D.of the original standard size valve guides.  The ones in the engine rangefrom .530 to .550 O.D, but I figure they've all been replaced at least atime or two (or three, or four).  So, I don't know if I need .010" over,.020" over, or some other larger guide I can cut down to size.Anybody know the O.D. of standard size valve guides in an A-65/75? Thanks in advance, Dave MordecaiPanacea, FLwhere NX520SF patiently awaits her crankshaft to return from Rick Roman's.....________________________________________________________________________________
Re: Pietenpol-List: Continental A-65/75 valve guide question
Original Posted By: kmordecai001(at)comcast.net
Subject: Re: Pietenpol-List: Continental A-65/75 valve guide questionDave,My Continental Manual lists as follows.TABLE OF LIMITS Min. Max.Valve Guide in Cylinder Head....Diameter .001T .0025THope this is what your looking for.Gene ----- Original Message -----
