Pietenpol-List: Re: Continental Valve Guides
Original Posted By: "D.Reid"
Subject: Pietenpol-List: Re: Continental Valve GuidesThanks Gene, but that's the interference fit between the valve guide and the borein the head. ie: The guide should be .001 to .0025 larger in O.D. than thebore in the head. The head is heated to expand it, and the guide chilled in thefreezer prior to pressing the guide in, making for a TIGHT fit. I can buy guides using the bore diameter's I need, but the places I've called onlylist them by oversize (+.010, +.020, etc) rather than by actual O.D, so I'llneed them to mic what they have so I get the right size (or perhaps I shouldsay oversize)Thanks,Dave in Panacea> > > > > TABLE OF LIMITS Min. Max. > Valve Guide in Cylinder Head....Diameter .001T .0025T > > Hope this is what your looking for. > Gene >Thanks Gene, but that's the interference fit between the valve guide and thebore in the head. ie: The guide should be .001 to .0025 larger inO.D. than the bore in the head.  The head is heated to expand it, andthe guide chilled in the freezer prior to pressing the guide in, making fora TIGHT fit.  I can buy guides using the bore diameter's I need, but the placesI've called only list them by oversize (+.010, +.020, etc) rather thanby actual O.D, so I'll need them to mic what they have so I get the right size(or perhaps I should say oversize) Thanks, Dave in Panacea  > > > > > TABLE OF LIMITS Min. Max. > Valve Guide in Cylinder Head....Diameter .001T .0025T > > Hope this is what your looking for. > Gene >________________________________________________________________________________
