Pietenpol-List: elevator cable routing under the rear seat
Subject: Pietenpol-List: elevator cable routing under the rear seatHello all, From my recent inquires, it's now obvious that I'm working on my controls. Today'squestion is: Do people still run the elevator cables thru the wood crossmember under the rear seat, or should pulleys be located directly behind therear seat to guide the cables from the control sticks up to the bell crank?If people still run the cables in that area without pulleys, are wear surfacesor some form of guides fabricated? Thank you for your help, John ---------------------------------See the all-new, redesigned Yahoo.com. Check it out.________________________________________________________________________________
RE: Pietenpol-List: elevator cable routing under the rear seat
Subject: RE: Pietenpol-List: elevator cable routing under the rear seatI used pulleys in mineJack PhillipsNX899JP-----Original Message-----[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of JohnEganSent: Thursday, August 03, 2006 11:26 AMHello all,controls. Today's question is: Do people still run the elevator cablesthru the wood cross member under the rear seat, or should pulleys belocated directly behind the rear seat to guide the cables from thecontrol sticks up to the bell crank? If people still run the cables inthat area without pulleys, are wear surfaces or some form of guidesfabricated? Thank you for your help,John _____ See the all-new, redesigned Yahoo.com. Check it out. _________________________________________________This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited.Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N________________________________________________________________________________
Re: Pietenpol-List: elevator cable routing under the rear seat
Original Posted By: "Lynn Knoll"
Subject: Re: Pietenpol-List: elevator cable routing under the rear seatI used pulleys in mine also.Dan HelsperPoplar Grove, IL.________________________________________________________________________________
Subject: Re: Pietenpol-List: elevator cable routing under the rear seatPulleys here also.Lynn KnollPiet/VairWichita________________________________________________________________________________
Subject: Re: Pietenpol-List: elevator cable routing under the rear seatI'm working on mine now too. I used a pulley to run the line to the top of the bellcrank, but the line to the bottom of the bellcrank is almost straight, so I'm running that cable through a piece of copper tubing. I put an oak doubler under the rear of the rear seat support to give some strength to the hole the copper tubing will mount in. I have a tubing flare tool that I willl use to bend a nice flange on both ends of the tubing after it is in place. I got this idea from Tony Bingelis's books. I'm not finished yet so take it for what its worth.....Ben________________________________________________________________________________
Original Posted By: John Egan
Subject: Re: Pietenpol-List: elevator cable routing under the rear seatPulleyJim MarklePryor, OK214.505.6101 ----- Original Message -----
Subject: Pietenpol-List: elevator cable routing under the rear seatPulleys on 41CC. I sent a photo of the setup off-list.Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
Subject: Re: Pietenpol-List: elevator cable routing under the rear seatI made hard wood guides. I got the idea from an old timer at Brodheadwho said he did that many many years ago on an aircamper he still flies.The wood and cable show no ware, just a polishing from the cablemovement He said. I drilled the ash at a roughly at the angle neededfor the cables, then made the holes better with a Dremmel. I made anaccess cover under this area so I can watch it closely and put onpulleys if it comes to that. Leon S..________________________________________________________________________________
Subject: Re: Pietenpol-List: elevator cable routing under the rear seatNX18235 has the rudder cables running through nylon tubing from under the seat to just before the cable exits the fuselage. The tubing acts as a continuous fairlead.Greg C. ----- Original Message -----
Original Posted By: "glich7(at)juno.com"
Subject: Re: Pietenpol-List: elevator cable routing under the rear seatIn a message dated 8/3/2006 10:30:03 AM Central Standard Time, johnegan99(at)yahoo.com writes:Do people still run the elevator cables thru the wood cross member under the rear seat, or should pulleys be located directly behind the rear seat to guidethe cables from the control sticks up to the bell crank? If people still run the cables in that area without pulleys, are wear surfaces or some form of guides fabricated? John,It seems that most folks use at least one pulley on the cable that goes up to the top of the bellcrank. However, there is absolutely NO reason that a pulley must be used there. I didn't use a pulley, and there is NO wear going onin that area, after well over 300 hrs operation. It simply rides on a piece ofhardwood, however, I did tighten up one of the turnbuckles up a couple of years ago, and maybe after a few more years I may have to make another slight adjustment. Copper tubing is not a very good fairlead, because it has poor abrasion characteristics, and there is also what is called Dissimilar Metal Corrosion. Pulley's add complexity to the design, as well as the risk of a cablejumping out, and jamming the control cable. The beauty of the Pietenpol is inthe simplicity of it's design. Changing even simple things like this adds an incredible amount of time, and thought that it takes you to build, and after allthat extra effort, you still haven't made an improvement. Stick to the plans, and just Git 'er done !!Chuck G.NX770CG________________________________________________________________________________
Subject: Re: Pietenpol-List: elevator cable routing under the rear seatI used pulleys also, but let me tell you about a problem that I am now in the process of correcting, that others have heard me complain about.My rudder cables pass under the seat and run thru the pulleys. After that they join with the tailwheel cable with nicropress fittings. I had set the rudder 10 degrees off to the right to counter the prop force. My plane has had a tendency to suddenly veer off to the left on the takeoff run shortly after the tail came up. This has lead to a couple of aboarted takeoffs, luckily with no damage. The conclusion I have reached is that the tension on the tail wheel releases as it leaves the ground changing the rudder position causing the plane to suddenly veer off if I'm not anticipating it. I am re rigging the cables, running seperate cables from the bar.Dick N. ----- Original Message -----
Subject: Re: Pietenpol-List: elevator cable routing under the rear seatPulleys.On 8/3/06, John Egan wrote:>> Hello all,>> From my recent inquires, it's now obvious that I'm working on my> controls. Today's question is: Do people still run the elevator cables> thru the wood cross member under the rear seat, or should pulleys be located> directly behind the rear seat to guide the cables from the control sticks up> to the bell crank? If people still run the cables in that area without> pulleys, are wear surfaces or some form of guides fabricated?>> Thank you for your help,>> John>> ------------------------------> See the all-new, redesigned Yahoo.com. Check it out.>>-- Rick Holland"Logic is a wreath of pretty flowers, that smell bad"________________________________________________________________________________
Subject: Re: Pietenpol-List: elevator cable routing under the rear seatYou make a good point Chuck, I have 2 pulleys under the seat for my elevatorcables but the pully for cable going to the lower bellcrank fitting neverturns when I move the stick and has no reason to be there. I am sure twoholes in an ash block as you have done is fine.RickOn 8/3/06, Rcaprd(at)aol.com wrote:>> In a message dated 8/3/2006 10:30:03 AM Central Standard Time,> johnegan99(at)yahoo.com writes:>> Do people still run the elevator cables thru the wood cross member under> the rear seat, or should pulleys be located directly behind the rear seat to> guide the cables from the control sticks up to the bell crank? If people> still run the cables in that area without pulleys, are wear surfaces or some> form of guides fabricated?>> John,> It seems that most folks use at least one pulley on the cable that goes up> to the top of the bellcrank. However, there is absolutely NO reason that a> pulley must be used there. I didn't use a pulley, and there is NO wear> going on in that area, after well over 300 hrs operation. It simply rides> on a piece of hardwood, however, I did tighten up one of the turnbuckles up> a couple of years ago, and maybe after a few more years I may have to make> another slight adjustment. Copper tubing is not a very good fairlead,> because it has poor abrasion characteristics, and there is also what is> called Dissimilar Metal Corrosion. Pulley's add complexity to the design,> as well as the risk of a cable jumping out, and jamming the control cable.> The beauty of the Pietenpol is in the simplicity of it's design. Changing> even simple things like this adds an incredible amount of time, and> thought that it takes you to build, and after all that extra effort, you> still haven't made an improvement. Stick to the plans, and just Git 'er> done !!>> Chuck G.> NX770CG>-- Rick Holland"Logic is a wreath of pretty flowers, that smell bad"________________________________________________________________________________
Subject: Re: Pietenpol-List: elevator cable routing under the rear seatIn a message dated 8/4/2006 1:21:14 PM Central Standard Time, at7000ft(at)gmail.com writes:You make a good point Chuck, I have 2 pulleys under the seat for my elevator cables but the pully for cable going to the lower bellcrank fitting never turns when I move the stick and has no reason to be there. I am sure two holesin an ash block as you have done is fine. RickRick,I looked at your picture, and didn't see any threads sticking through the lock nut. Was this a picture of the pre-fit ? At least two threads must protrude through the nut, but no more than four.Chuck G.NX770CG________________________________________________________________________________
Original Posted By: TBYH(at)aol.com
Subject: Re: Pietenpol-List: elevator cable routing under the rear seatYes its just pre-fit, I haven't even glued the side ply and firewall on yet.But thank you for vigilance, I welcome your inputs any time.RickOn 8/4/06, Rcaprd(at)aol.com wrote:>> In a message dated 8/4/2006 1:21:14 PM Central Standard Time,> at7000ft(at)gmail.com writes:>> You make a good point Chuck, I have 2 pulleys under the seat for my> elevator cables but the pully for cable going to the lower bellcrank fitting> never turns when I move the stick and has no reason to be there. I am sure> two holes in an ash block as you have done is fine.>> Rick>> Rick,> I looked at your picture, and didn't see any threads sticking through the> lock nut. Was this a picture of the pre-fit ? At least two threads must> protrude through the nut, but no more than four.>> Chuck G.> NX770CG>-- Rick Holland"Logic is a wreath of pretty flowers, that smell bad"________________________________________________________________________________
