Pietenpol-List: Fuselage length, wing placement and wheel axle placement
Subject: Pietenpol-List: Fuselage length, wing placement and wheel axle placement(long)Hello to everybody!First of all, a big THANK YOU to the list for the response to the firstbunch of questions! I collected and stored all the photos and documentsyou guys provided, and I especially thank Chris Tracy who provided thelink to his website and to Chris Bobka's document about wheel axlesplacement. Again, thanks!Well, I decided to fire up the CAD and try to assemble a virtual Pietwith all the modifications/clarifications available so far. Not toredesign the Piet itself but just to be a quick and clean method tocheck dimensions and placements. And here is, obviously, whereconfusion begins. :-(Before getting into the hang of it, I want to explain a couple ofpoints which form the base for the whole discussion:1) Our Piet is not going to enjoy any of the three de-facto "standard"powerplants (Ford Model A, Corvair or Continental A65-8) simply becausenone is available to us in Europe (even A65-8 are rarer than hen'steeth these days, in spite of their past wide availability here).Therefore, the powerplant will have to be something quite different,probabily derived from a modern gas/diesel auto engine or somethinglike that. When time comes, appropriate calculations will be made forengine placement, in order to obtain the correct Center of Gravityrange. I'm familiar with this procedure as I've already done it in thepast for two other airplanes, and they then checked correctly on thescales.2) Because of the aforementioned point, I decided to reference all mywork to the original 1933 Improved Plans i.e. considering the Piet ashaving the wing position determined by the cabane struts at rightangles with the upper longeron. That is, with the important change ofthe 172 3/8" long fuselage (because we believe we need the increasedtail arm as we assume a longer nose). As already said, that's where confusion begins, because after lookingat all the photos I could see, reading Chris Bobka's comments, and evenchecking the Weight and Balance sheet provided by Don Pietenpol, I sawthat the wing position can be quite different from the original one,and not always the same. This is not very good from an engineeringstandpoint, because every kind of W&B calculation assumes a CG rangewith respect to the airplane Center of Lift, and not the other wayaround. Not to mention the fact that, as wing placement change, so doesthe tail arm length, which should be something to be taken veryseriously and not changed all too easily.Chris Bobka's document is fine in that it works out a well-weighedlogical conclusion from a huge amount of data, but it does NOT mentionthe WING anywhere. However, let's start working on BOTH fuselages(standard and long) using some known data:1) Standard fuselage: Bobka's axle distance from firewall: 17"2) Long fuselage: Bobka's axle distance from firewall: 21"3) Distance between firewall and wing leading edge, std fuselage: 6.8"4) Distance between firewall and wing leading edge, long fuselage: 8.8"5) Most rearward CG position (Don Pietenpol): 33% or 20" from LEOkay, working out the math makes for TWO DIFFERENT distances betweenwheel axle and most rearward C of G position for the two fuselages:7.8" for the LONG fuselage, and 9.8" for the STANDARD fuselage.Logic says that the distance should be the same for both fuselages, soobviously one of them is not correct.My own understanding says 7.8" is way too little. When the Piet issitting without pilots and with empty wing tank, the CG ought to bevery close to its most FORWARD position, which is probabily AHEAD ofthe wheel axle in level flight, meaning the fuselage will barely standon the tailwheel (if it has not already tipped over). 9.8" does notlook really good either, but it's the closest (by 1/2" if I'm notmistaken) to the measurements on the Improved 1933 Plans.Again, I state that the wing is going to be exactly where shown on theplans, and the correct placement of the powerplant will bring the CGrange within the correct limits. And none of the measurements forplacing Ford/Corvair/Continental engines will apply, as the powerplantwill NOT be either one of these.So, where should I place my wheel axles?All the Pieters out there, where is YOUR wheel axle and YOUR wingleading edge with respect to the firewall, and HOW does your Pietbehave during landing and on the ground?Thanks in advance for the answers.SeeYa!Andrea VavassoriVolksplane VP-1 I-BYRAEAA #348037FCAP I-146Homepage: http://andrea.modelberg.it________________________________________________________________________________Date: Sat, 12 Aug 2006 01:05:32 -0700 (PDT)
Re: Pietenpol-List: Fuselage length, wing placement and wheel axle placement
NX18235 has the wing LE 13.5 inches aft of the firewall. The axle is 20 inches aft of the firewall.Ground handling is superb for a skid equipped brakeless aircraft.Greg Cardinal> So, where should I place my wheel axles?>> All the Pieters out there, where is YOUR wheel axle and YOUR wing> leading edge with respect to the firewall, and HOW does your Piet> behave during landing and on the ground?>> Thanks in advance for the answers.>> SeeYa!>> Andrea Vavassori>> Volksplane VP-1 I-BYRA> EAA #348037> FCAP I-146> Homepage: http://andrea.modelberg.it>>> ________________________________________________________________________________
Original Posted By: Andrea Vavassori
I would ask that everyone that replies gives fuselage and gear type, please.Gene ----- Original Message -----
Subject: Re: Pietenpol-List: Fuselage length, wing placement and wheel axle placement...In a message dated 8/12/2006 2:25:11 AM Central Standard Time, andrea(at)modelberg.it writes:3) Distance between firewall and wing leading edge, std fuselage: 6.8"Andrea,Drawing No. 1 (Improved 1933 plans) shows the wing leading edge 7.5" behind the firewall.The Pietenpol is a forgiving design, in the dimensions of the final product, evidenced by the wide variety of Flying airplanes out there. It is also claimed to have had a wider variety of engines, than Any Other Airplane in History!!{ All the Pieters out there, where is YOUR wheel axle and YOUR wingleading edge with respect to the firewall, and HOW does your Pietbehave during landing and on the ground? } NX770CG has a plans built short fuselage, with the axle 17" aft of the firewall. She has gone through many retrofits during 'er short life of 4 + years (first certified 1/8/02). When first built, she had a Model A engine withplans dimensions for the engine mount, tail skid, no brakes, and the cabanes were vertical. I taxied 'er quite a bit in this configuration, however, with my210 lbs weight, the C. of G. was too far aft for safe flight. It was very easy to do a turnaround, almost pivoting on one wheel (remember no brakes). Imoved the wing back 3 1/2" from vertical, and added 14 lb ballast (cast from lead and mounted to the bellhousing flange for the transmission), and got the C.of G. within safe limits. This retrofit caused the ground handling to change a little bit, in that I couldn't do quite as quick turnaround. Doug Bryant did the first 3 flights in this configuration, and I logged 23 hours in this configuration, but we couldn't get that pesky gremlin out of the Model A engine- which caused Three deadstick landings. I wrestled with that engine the entire year of '02, so the first 6 months of '03 was spent retrofitting the firewall forward to accept a Continental A65 - 8 engine. In order to maintainthe safe C. of G. range (15" to 20" aft of the leading edge), I built the engine mount 8" longer than the Continental engine mount plans, but used the next sizewall thickness and same O.D. for the tubing. The cabanes are still 3 1/2" aft of vertical. The ground handling did not change, but the empty weight wasreduced by 60 lbs, and the power was almost doubled. Needless to say, this wasa Very significant improvement in takeoff, climb and reliability. I haven't had ANY problems with this Continental engine, and I truly LOVE that engine !! Before flying to Brodhead and Oshkosh in '03, I added brakes, but not a tailwheel, and finished flying the required 40 + hours of the test period. Without brakes, it was very difficult to taxi on hard surface, but handled finein the grass. I thought I could steer with the brakes / tail skid after landing on hard surface, but this proved to be WRONG !! During that cross countryflight, I ran off the hard surface runway at two different airports. I could easily blame that on the stiff crosswind, and when I tried to steer with the brakes, the tail came up abruptly, and I almost lost it both times...just let 'er go off the runway between the runway edge lights. Before my America Tour '04, I added a tailwheel, and changed out the bunji struts, for spring struts. That was a 3100 mile cross country trip !! Noproblems with the ship, and the weather was great. She has been in this configuration for the past two years, and I'm having a Blast with 'er !!Chuck G.NX770CGWichita, KShttp://nx770cg.com/________________________________________________________________________________Date: Sat, 12 Aug 2006 11:24:10 -0400
Re: Pietenpol-List: fuse survey
Andrea had asked for a axle/wing placement survey, and the first response gave those figures without mentioning which fuselage or gear types, which makes all of the difference in the world. Likewise, wink wink, the fuselage and gear type does not do much without the axle/wing placement info . . . Gene ----- Original Message -----
Subject: Re: Pietenpol-List: fuse survey>Andrea had asked for a axle/wing placement survey, and the first response gavethose figures without mentioning which fuselage or gear types, which makes allof the difference in the world. Likewise, wink wink, the fuselage and geartype does not do much without the axle/wing placement info . . .Gene,Thanks so much for pointing that out. In fact I forgot to ask thefuselage type in the first istance. However, It's not absolutelynecessary to know the gear type because axle distance from firewallwill suffice for doing the maths.SeeYa!Andrea VavassoriVolksplane VP-1 I-BYRAEAA #348037FCAP I-146Homepage: http://andrea.modelberg.it________________________________________________________________________________
Excellent clarification Gene.NX18235 is a long fuselage with Jenny style gear. Wing LE is 13.5 inches aft of the firewall. Axle is 20 inches aft of the firewall. Greg C. ----- Original Message -----
Pietenpol-List:
Happy weekend Pieters.....I have two questions 1. ACS has a complete overhaul kit for my Marvel Schebler MA3PA carb for $207.00 is that the going price or is there someplace else that has better prices. I tried Fresno air parts and they don't carry them...... 2. The total thickness of my prop flange, Prop and crush plate measure within .001" of exactly 4". It amazes me that my new Tennessee prop's hub is that close to perfectly 3 1/2". Prop bolts are available in 4" grip length. Sooo should I go with a 4" grip length bolt or should I go the next step down which would be 3 7/8". I've never dealt with a wood prop before. everyone says they compress some under the pressure from the bolts but I have no idea how much to expect and I don't want to end up with excessive washers under the nuts. my guess is that 3 7/8" would be too short but prop bolts are too expensive to guess at. Thanks in advance and enjoy your weekend....Ed G in Florida starting to see a faint light in the tunnel. ________________________________________________________________________________
Original Posted By: "Andrea Vavassori"
I'll aswer as much as I can remember here at home.I have the short Fuse, NX2RN. My wing is back 4.5" from vertical. I don't recomend this as it isn't the easiest getting in and out of rear cockpit. I also had to add a 25 lb battery and 4 gal fuel in the nose to get proper CG. Axle is 19" aft of firewall.Dick N.----- Original Message -----
