Pietenpol-List: Fuse construction
Original Posted By: "Dan Loegering"
Subject: Pietenpol-List: Tulsa / Bartlesville Fly-InIs anyone planning on heading out to the Bartlesville OK (BVO) Fly-In this weekend ? It's a pretty big fly in.http://www.tulsaflyin.com/aircraft%20arrivals.htmI'm planning on arriving in NX770CG sometime late Saturday morning...weather permitting. Steve R., Chet Peek wil be there, and maybe Jim M. will be there.Anyone else planning on attending ???Chuck G.NX770CG________________________________________________________________________________Subject: Pietenpol-List: Fuse constructionDate: Fri, 22 Sep 2006 08:08:36 -0500
Original Posted By: Lou Wither
Re: Pietenpol-List: Fuse construction
Cub style gear?? Those must be GN-1's not Pietenpol. The GN-1 is a modified Pietenpol with enough changes to no longer be called a Pietenpol. I believe the cub gear mounting changes the location of the axle compared the Piet. Also the GN-1 has a modified airfoil with a different leading edge. That said, are you building from authentic Pietrenpol plans or the GN-1 plans?About the fuselage, the only challenge I faced was devising a sanding drum set-up to scarf the edges of the mating joint of the two pieces of plywood doublers on the sides of the fuse.I did not have to steam the longerons to pull the tail together.I use the West Epoxy system for all my construction.I used an office stapler to staple the gussets to the ribs and the fuselage rather than the tiny brads. Much quicker and easier.The only other challenge so far was to find an economical metal cutting bandsaw.I finally converted my wood cutting bandsaw to a multispeed using a DC motor with speed control.Roman BukoltBuilding a Corvair powered Pietenpol NX88XN----- Original Message -----
RE: Pietenpol-List: First flight..
Remember !! A Aircraft will stall at any airspeed but allways at the sameangle of attack !!!-----Original Message-----
Hane you installed your battery yet? That can add 25 lb to the firewall. You can also move the wing back 1 more inch, that will also help. Mine is back 4 1/2". I built a short fuse, not knowing at the start what engine to use. After deciding on an A-65 I also added a 4 gal reserve nose tank, a battery to the FW to get CG.Dick N. ----- Original Message -----
FW: Pietenpol-List: Fuse construction
RE: Pietenpol-List: Fuse construction
FW: Pietenpol-List: Fuse constructionI don't think anyone actually builds the exact plane that Pietenpol designed, too many modern materials available and necessary. Afterall who'd want to use a tractor mag when there are better options, or grade 3 bolts. Same goes for the original Rutan designs for the Varieze and Longeze, every builder adds or subtracts their own mods. That's why it's called experimental. But we still have the purist out there that insist it ain't a Piete unless it is build just like Bernard did, fer git abouut it dreamers. N-1003B's 4130 fuselage, 0-235Lycosauros engine and Aeronca wings, flies just fine thanks. Got $5 bucks that says my "Piete" can beat anyone out there's Piete in time to climb to 3000' agl, even the purist, how about Lakeland in Apr07. Better materials make better planes, just like the Papa John's Pizza commercial. Think Bernard would appreciate the improvements and still be proud to stick his name on the design.Gordon Bowen ----- Original Message -----
Pietenpol-List: Re: Fuse construction
Hello Dan,In thinking back, I believe the fuselage was fairly straight forward. There maybe some searching for measurements in other places on the plans. Once you buildup the sides it would probably be a good idea to build a jig to bring thesides together, upside down since the top longeron is flat. I would start fromthe front and work back to the tail in installing the cross-braces. Squarenessis obviously important. I wouldn't make any metal fittings until the woodworkis finished. Seem to get a better fit if you build them to your specificfuselage. I'd leave the firewall off until all the fittings and controls werebuilt, gets a little tight in there. I made the front seat framework permanentbut made the plywood seat removeable to service the rudder bar. I routedthe elevator cables through pulleys where they go under the seat. Helps for alittle smoother movement. It's a good idea to beef up the instrument panelswith laminated wood bows glued to the plywood. Adds a lot of strength for a verysmall weight penalty. Really, really resist the urge to add much of anything.The fuselage is quite strong if built with quality wood and good tight joints.I've found that out with some not so great landings! Try not to add muchto the panel, you won't use it anyway. The view outside is much better thanlooking at the panel. If you build it like the plans and expect a 1930's airplaneyou won't regret it.Don EmchNX899DERead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By: Gordon Bowen
FW: Pietenpol-List: Fuse constructionGordon,Greg Bacon just might take you up on this bet when he gets Mountain Piet back in the air.......Greg C. ----- Original Message -----
Original Posted By: gcardinal
FW: Pietenpol-List: Fuse constructionGREAT!!!!!! If we can find an honest man, then they can hold the bet money, five bucks is five bucks, it could be a temptation. Lakeland Apr07, I'll hook the turbocharger back up, take on the RV guys, get some respect for Piete Aficionados.Gordon----- Original Message -----
Re: FW: Pietenpol-List: Fuse construction
Subject: Re: FW: Pietenpol-List: Fuse constructionIn a message dated 9/22/2006 1:56:05 PM Central Standard Time, eng(at)canadianrogers.com writes:I think the key word here is "style". Cub style gear, not actual Cub gear. The 1933/34 improved Pietenpol Air Camper plans show a split axle "Cub style" landing gear. The J3 Cub, actually uses a 'Pietenpol Split Axle Landing Gear'. Bernard Pietenpol designed that gear out of some old gas pipe, long before any J3 Cub's came along. I have the 'Pietenpol Split Axle Style Gear', and changed out the bunji's for springs, several years ago. If I were to do it again, I would make the front cross piece of steel between the landing gear lugs / lift strut lugs, outof 4130, and maybe a little thicker than the 16 Ga. (.059") steel that it calls out on Drawing No. 3. As someone else pointed out, the steel parts shouldbe built AFTER the wood fuselage is complete. I've had that cross piece benddown away from the belly, several times. A hard landing applies a lot of negative G's to the lift strut, as well as when the landing gear bottoms out, pushes that cross piece into a bow away from the belly. That energy has to beabsorbed somewhere, and that cross piece is the place. I've seen this on several other Pietenpols, too. The problem seems to be isolated to the front one.I now have three #10 bolts down through the ash cross piece and this steel cross brace, and just this evening, I see where it has bent down a little bit between two of these bolts. I must have logged well over 500 landings in my plane, and I obviously still bounce one in once in a while !! This evening, I was exploring the slow flight characteristics again (at about 2000' AGL), power setting on the trusty ol' A65 at about 1500 rpm, and Igot the ASI to indicate 30 mph for an extended time, and she just slowly mushed forward, losing altitude just at a low rate. I love flying this plane,and she never ceases to amaze me !!Chuck G.NX770CGSmokin' to Bartlesville in the morning !!________________________________________________________________________________
Original Posted By: "Skip-Cinda Gadd"
Subject: Re: FW: Pietenpol-List: Fuse constructionIn a message dated 9/22/2006 11:34:13 P.M. Eastern Daylight Time, Rcaprd(at)aol.com writes:That energy has to be absorbed somewhere, and that cross piece is the placeChuck I'm no engineer, but what you said there got me thinking. Maybe this energy should be absorbed by bowing this metal cross piece? If you stiffen this piece, then does some more critical (or more difficult to replace/repair) part then have to take the load? Food for thought...Boyce________________________________________________________________________________
Original Posted By: Andimaxd(at)aol.com
Chuck,I have seen this strap bent down on several Piets at Brodhead.What I believe happens is, you have end grain of a hard wood, ash cross piece,pushing into side grain of soft wood spruce, lower longerons. Grega noticed thisand changed from a strap, tension only to a U-channel, tension and compression.It is one on the Grega mods I am adopting for my Piet. I am using 4130 rectangulartube, because it is lighter than any U-channel I could find.Hope you have great weather for Bartlesville, the Wx here is scud and storms.Skip, Hales Landing WV----- A hard landing applies a lot of negative G's to the lift strut, as wellas when the landing gear bottoms out, pushes that cross piece into a bow awayfrom the belly. That energy has to be absorbed somewhere, and that cross pieceis the place. I've seen this on several other Pietenpols, too. The problemseems to be isolated to the front one. I now have three #10 bolts down throughthe ash cross piece and this steel cross brace, and just this evening, Isee where it has bent down a little bit between two of these bolts. I must havelogged well over 500 landings in my plane, and I obviously still bounce onein once in a while !! Chuck G.NX770CGSmokin' to Bartlesville in the morning !!________________________________________________________________________________
Subject: Re: FW: Pietenpol-List: Fuse constructionIn a message dated 9/23/2006 6:29:54 AM Central Standard Time, RAMPEYBOY(at)aol.com writes:That energy has to be absorbed somewhere, and that cross piece is the placeChuck I'm no engineer, but what you said there got me thinking. Maybe this energy should be absorbed by bowing this metal cross piece? If you stiffen thispiece, then does some more critical (or more difficult to replace/repair) partthen have to take the load? Food for thought...Boyce Yes, you certainly are right about the energy being absorbed by another part. However, bowing the cross piece is NOT the answer, because then you willbe wallowing out the bolt holes at the lug fittings. I think this cross piece is just the weakest link, and the robust design of the Pietenpol can certainly handle the load, wherever it is transferred. The whole trick is...to land as softly as a Butterfly with sore feet !! :)Chuck G.NX770CG________________________________________________________________________________
Subject: Re: FW: Pietenpol-List: Fuse constructionIn a message dated 9/23/2006 10:26:18 A.M. Eastern Daylight Time, Rcaprd(at)aol.com writes:The whole trick is...to land as softly as a Butterfly with sore feet !! :)We do that all the time don't we?? I mean when nobody is watching!________________________________________________________________________________
Subject: Re: FW: Pietenpol-List: Fuse constructionIn a message dated 9/23/2006 7:29:15 AM Central Standard Time, csfog(at)earthlink.net writes:Chuck,I have seen this strap bent down on several Piets at Brodhead.What I believe happens is, you have end grain of a hard wood, ash cross piece, pushing into side grain of soft wood spruce, lower longerons. Grega noticedthis and changed from a strap, tension only to a U-channel, tension and compression. It is one on the Grega mods I am adopting for my Piet. I am using4130 rectangular tube, because it is lighter than any U-channel I could find.Hope you have great weather for Bartlesville, the Wx here is scud and storms.Skip, Hales Landing WVI agree with ya, Skip. I think you have a good mod there, just so the rectangle tube isn't very wide on the minor axis, and the wall thickness doesn'thave to be as thick as the strap, either. I sure do miss those West Virginia hills !! Hey...WVU is kickin' butt in football !! GO MOUNTAINEERS !!!Chuck G.NX770CG________________________________________________________________________________
Original Posted By: Dan Loegering
Dan:Two of THE most talked about bugaboos with the fuselage that have not been mentioned yet are:(1) decide on your gear type and location BEFORE building. Retrofitting the Jenny style gear to the '32 fuselage or later is a bear;(2) make SURE you understand the construction of the tailpost. Read it, draw it, read it again. Too many people have glued in two 1/2 inch pieces and tried to pull them together. It does not work like that. Even after several readings, it is more difficult in practice than it looks.As for the discussion that has made it into this thread regarding the steel strap across the belly, I maintain that it is not SUPPOSED to take any compression loads and does not need to be square stock or anything else. There is nothing wrong with a wooden fuselage or any other component flexing on landing. The strap was added as an afterthought, and only as an optional suggestion per the plans, as a safety device to tie the struts together in case the bolts pulled out of the fuselage. at the gear/strut fitting. The wood, metal, workmanship, and maintenance and upkeep of amateur builders in the 1930's was such that a rotten longeron or two was not out of the question. The quality materials and workmanship we have on this list, I believe, negates any need for that strap. I am not going to install it, just something else to bow, corrode, hold moisture against the wood, and look bad.Just my two cents worth.Gene ----- Original Message -----
Gene and allTell me if I am wrong here in thinking that since I am using the Jenny type LG, these issues dont apply. The cross brace wires and the bungees absorbing shock straight upwards shouldn't cause compression loading in the same way. Am I correct about that?Dick N. ----- Original Message -----
Dick:I agree that the Jenny gear loads the fuselage differently and may not make the fuselage bow the same, but I think the original purpose of the strap would still be there, as a safety device in the last resort to hold the wings on if the fitting should pull out, or actually to prevent the fitting from pulling out. I think that this is an extremely unlikely concern.Just to give another example of this type of concern, the seat belts in the Travel Air originally attached around two oak seat rails. Because there was an instance where the oak rails became so rotten that they broke off and the pilot, seat, belts and all fell out of the airplane, the belts were moved to attach to the longeron. I do not anticipate that solid oak rails in my airplane (or any other part) will rot inside the hangar (they were probably kept outside then) I have mine attached to the oak like they originally were. Poor conditions, poor maintenance, poor inspections created the problem. How a solid piece of oak could rot that much without being noticed is beyond me.Gene ----- Original Message -----
Rick,The gear on my Piet uses GN-1 front fittings for the front and back, the aft GN-1fitting does not have the lift strut attach. The rectangular tube I found is1 1/2 X 3/4 .049 from Aircraft Spruce. I would have used .035 if I could havefound any. I may use a strap on the aft fitting. Grega has an N brace betweenthe front and back U channel. I do not plan to use that part of his design.If I had Piet fittings and wanted to use a rectangular tube, I might remove thestrap and just modify the ends of the rectangular tube so it could be attachedto the Piet gear fitting.Skip What if a piece of rectangular tubing (as long as would fit between the fittings)was welded along the two inch strap? Probably only on the front strap sincethe back doesn't seem to have the problem. Were you thinking of something likethis Skip or are you also building the GN-1 gear fittings? Rick H.________________________________________________________________________________Date: Sun, 24 Sep 2006 14:34:58 -0700
Original Posted By: "Dave Abramson"
Subject: Re: Pietenpol-List: Fuse constructionSlightly off topic, when building the fuselage, do you have to steam the lower longeron to get the bend in it? The top one looks straight, the bottom definitely looks to have a bend. Curious mind wants to know, now I go back tolurking!Boyce________________________________________________________________________________
Hi Boyce,No, you do not have to steam the lower longeron to bend it. I think theonly piece I had to steam was the top piece of spruce on the wing ribs.That is a pretty good bend! Cheers, Dave-----Original Message-----
