Pietenpol-List: Airworthiness Cdertificate Inspection
Original Posted By: Michael Conkling
I received my Airworthiness Ceertificate for my Piet last week. I used a localDesignee whose standard charge is $300 plus mileage. When we scheduled the inspectionhe said that he might have his supervisor along to supervise the inspection.My first thought was that he was liable to be extra picky with his FAAsupervisor looking over his shoulder. On the day of the inspection the Designeeand the FAA supervisor both showed up. The inspection went quite smoothly.The paperwork was in order, and they did not find any fault with the aircraftother than spotting two nuts that had not been safetied. They did have afew constructive suggestions on minor items. When I received the C of A I gotout my checkbook to pay the Designee but he said "I can not charge for a supervisedinspection. I have to do supervised inspections periodically to maintainmy status and I am not allowed to charge for them." I lucked in on that one.The FAA is pushing the recommendation that homebuilts have ELTs during the testperiod even though they recognize that the regulations do not require it. Iwas not going to install one until my time was flown off, but I have gone aheadand purchased one. I think I am going to mount it on the floor of the rearpit, but I have not figured out where the antenna will go.Between the need for more tailwheel time, the weather in Michigan, and my travelschedule, I suspect I will not get my first flight in until Spring, but we shallsee.Bob HumbertBattle Creek, MIN491RHI received my Airworthiness Ceertificate for my Piet last week.  I useda local Designee whose standard charge is $300 plus mileage.  When wescheduled the inspection he said that he might have his supervisor along to supervisethe inspection.  My first thought was that he was liable to be extrapicky with his FAA supervisor looking over his shoulder.  On the dayof the inspection the Designee and the FAA supervisor both showed up.  Theinspection went quite smoothly.  The paperwork was in order, and they didnot find any fault with the aircraft other than spotting two nuts that hadnot been safetied.  They did have a few constructive suggestions on minoritems.  When I received the C of A I got out my checkbook to pay the Designeebut he said "I can not charge for a supervised inspection.  I haveto do supervised inspections periodically to maintain my status and I am not allowedto charge for them."  I lucked in on that one. The FAA is pushing the recommendation that homebuilts have ELTs during thetest period even though they recognize that the regulations do not require it. I was not going to install one until my time was flown off, but I havegone ahead and purchased one.  I think I am going to mount it on the floorof the rear pit, but I have not figured out where the antenna will go. Between the need for more tailwheel time, the weather in Michigan, and mytravel schedule, I suspect I will not get my first flight in until Spring, butwe shall see. Bob HumbertBattle Creek, MIN491RH________________________________________________________________________________Date: Wed, 18 Oct 2006 09:40:49 -0500
RE: Pietenpol-List: Airworthiness Cdertificate Inspection
