Pietenpol-List: T-88 vs. urethane (Gorilla Glue)
Original Posted By: KMHeide
>From the KRNet archives (not posted by me):>I just called the Gorilla Glue folks at the phone number on the bottle.>Tensile strength on Douglas Fir is 1700 psi. T-88 is 7000 psi (although>it's not given as to what kind of wood was tested). Spruce has a>tensile strength of something like 10,000 psi parallel to the grain and>130 perpendicular to the grain, and there are other factors involved>as well, but you might could argue for most applications that either>would do. But T-88 is stronger than Gorilla Glue, and I personally>would use T-88.>>One other deciding factor might be shelf life. The bottle of GG that I>picked up is less than a year old and has only been opened once, and>very little was used, but it's solid as a rock. T-88 lasts for years with >no>perceptible change. I've never seen it go bad. For airplane use, I would>simply use the best.There was also mention made of the fact that urethane glues will foam up in the joint, causing some widening of the joint with resultant loss of tolerance even if clamped up tight. What you end up with is hardened foam in the joint and the strength of the joint becomes the strength of the foam. Based on what I've heard about Gorilla Glue and other similar products, they have their place but not on aircraft structures.Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net_________________________________________________________________Talk now to your Hotmail contacts with Windows Live Messenger. ________________________________________________________________________________Date: Mon, 27 Nov 2006 14:59:45 -0800 (PST)
Re: Pietenpol-List: Chuck G
My address is 840 Woodley Dr., Atlanta,Ga, 30318. Gardiner Mason ----- Original Message -----
Re: Pietenpol-List: T-88 vs. urethane (Gorilla Glue)
Original Posted By: "jimboyer(at)hughes.net"
Subject: Re: Pietenpol-List: T-88 vs. urethane (Gorilla Glue)In a message dated 11/27/2006 5:59:24 P.M. Eastern Standard Time, taildrags(at)hotmail.com writes:Based on what I've heard about Gorilla Glue and other similar products, they have their place but not on aircraft structures.Oscar ZunigaI absolutely agree with Oscar. I have used urethane glues extensively, but would never consider them for aircraft. Then again, what do I know? A man I met in NC named John Jeffries built his entire airplane using Titebond III, thestuff you get right off the shelf at Lowes. As far as I know, it is still flying.Ron________________________________________________________________________________Date: Tue, 28 Nov 2006 05:50:17 +0000 (UTC)
RE: Pietenpol-List: T-88 vs. urethane (Gorilla Glue)
Subject: Re: Pietenpol-List: T-88 vs. urethane (Gorilla Glue)In a message dated 11/28/2006 12:53:11 A.M. Eastern Standard Time, jimboyer(at)hughes.net writes:Hi Ron, I don't believe Titebond III is a urethane glue; it is an alphatic resin and is much more resistant to moisture, etc. It is a very good woodworking glue. Cheers, Jim I realize that, Jim. I was just pointing out another instance where someone used an adhesive that might not be appropriate for aircraft. Harvey then wrote about using the urethane glue, then having to spend hours cleaning up the part after the glue expanded and cured. This is one majorreason I would never even consider it for a Piet. I use it in my sign business when I need to glue and clamp up narrower widths of wood to produce widerboards. For this purpose, it is great because it is strong and easy to sand and clean up the joints (which must be perfect).Ron________________________________________________________________________________
I didn't mean to suggest using it as a structural glue, but it has some great uses in the model world. Holding hinges in the wood, locking ribs onto a trailing edge sheet, etc.----- Original Message -----
