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________________________________________________________________________________Date: Wed, 20 Dec 2006 15:19:51 -0500
Pietenpol-List: diesel Piet
RE: Pietenpol-List: diesel Piet
Oscar,The Piets built to the Jim Wills UK plans only have one jury strut (as doesmine).CheersPeterWonthaggi Australiahttp://www.cpc-world.com-----Original Message-----
Re: Pietenpol-List: Jury struts
Subject: Re: Pietenpol-List: Jury strutsIn a message dated 12/20/2006 3:55:15 PM Central Standard Time, HelsperSew(at)aol.com writes:Addressing the subject of placement of the jury struts: My eyeball engineering and gut feeling says that harmonic vibration of the struts would notbe a factor in a slow vehicle such as the Piet. Dan,Harmonics Certainly IS a factor in the Pietenpol. The engine causes vibrations, as well as the slipstream. I've experienced short negative G's thatMike C. spoke about, and Jack P. gave a good explanation as to why the Jury Struts are NOT in the middle of the Lift Struts. Jury struts Should be used on both the for and aft lift struts.Here is some pics of how I did mine:http://nx770cg.com/Wing.htmlA high speed connection would be advised, because there are so many pictures. Scroll down through, and you'll see the construction of the entire wing.Chuck G.NX770CG________________________________________________________________________________
