Pietenpol-List: snow day for Rick Holland
Re: Pietenpol-List: Strut vibration
Subject: Re: Pietenpol-List: Strut vibrationIn a message dated 12/21/2006 8:35:25 AM Central Standard Time, lshutks(at)webtv.net writes:Speaking of strut vibration, I remember reading in one of the old backissues of the BPNews where a builder said BHP told him not to tightenthe bottom lift strut attach bolt tight against the fus. fitting. Leavea little slack. this is to keep a vibrating strut from transferring itsmovement to the fus. fitting causing possible Work hardening andfailure. No problem at the top fitting as the "lolly pop" fitting (asChuck calls it) can move with the strut. This all if you use BHPsflattened end steel struts as shown on he plans. Leon S. Breathing asigh of relief that the blizzard in Colorado is going north east to Neb.rather than east to Ks.Leon,I've never heard that one from B.H.P. !! I don't think it would be much of a problem if lift struts are installed. Work hardening is much more prone to Aluminum...another reason to stick with the steel struts. I don't like the idea of leaving those lower strut bolts a little loose...I think it would wallowout the bolt holes.That is some kinda storm, huh ??!! I just heard that Interstate 70 is still closed down from yesterday !!Merry Christmas to all !!Chuck G.NX770CG________________________________________________________________________________Date: Thu, 21 Dec 2006 16:29:19 -0800 (PST)
Re: Pietenpol-List: Jury Strut - flying wing strut attach method
Original Posted By: "Ed G."
Subject: Re: Pietenpol-List: Jury Strut - flying wing strut attach methodDave,Yes, thats what I did. It worked out nicely because the strut length is 10 feet; I bought 4 and carlson, (Skytek) cut them into 8', 2'' sections which stowed nicely in my van.I had asked them for the specs and the details of their strut design for one of their own aircraft designs and also bought some 1" square bar stock which mates with the internal flats of the strut and fabricated the end attachments out of the bar stock per the detail drawing. I lengthened the cabanes about 2" so it all worked out nicely.Lou________________________________________________________________________________
