Hi DickPopping is caused by burning too small a flame on too big of a tip. use a smaller tip which will give you a smaller flame but still keep the flow of gas up enough to cool the tip. Ed G.>From: "Dick Navratil" >Reply-To: pietenpol-list(at)matronics.com>To: >Subject: Pietenpol-List: welding>Date: Sun, 21 Jan 2007 20:15:25 -0600>>A question for any who are more experienced at Oxy/actl welding. I was >making some parts today and kept having that popping in the molten pool. >Sometimes I can work away without having it occur but today it was blowing >holes in my tubing.That is real frustrating.>Can someone tell me what I am doing wrong.>Dick N.________________________________________________________________________________Subject: Pietenpol-List: saving hands and fingers on the table sawDate: Mon, 22 Jan 2007 13:51:22 -0600
Re: Pietenpol-List: welding
Original Posted By: "Steve Singleton"
Dick,Torch popping/backfiring is often caused by:1. Holding the inner cone of the flame too close to the puddle, thus overheating the tip.2. A partly clogged, or dirty, tip.3. Using too large a tip for the job, and reducing the gas flow too much in order to avoid totally melting the work piece.Possible solutions:Keep tips clean and use the recommended tip pressures for the tip size you are using (this may vary with the make of the welding outfit). Keep inner flame cone clear of the puddle (try 1/8" to 1/4" clearance and find what works for you). Don't use too large a tip for the job and try to throttle it back; take the time to switch to a smaller tip, rather than trying to manage with the too-large tip.Good luck!Graham Hansen (Pietenpol CF-AUN)________________________________________________________________________________
Re: Pietenpol-List: saving hands and fingers on the table saw
Original Posted By: Cuy, Michael D. (GRC-RXD0)[ASRC]
Hmmm, I wonder if this technology could be adapted to my circa 1950 Cast Iron Craftsman table saw.Glenn W. ThomasStorrs, CThttp://www.flyingwood.com ----- Original Message -----
