Pietenpol-List: Re: great evening viewing
Original Posted By: gus notti
Chris,I must have spent an hour (at least) just looking at center sections and occassionallygetting distracted and looking at other construction photos. That's agreat collection you put together. My wife was the only reason it didn't goon longer.Thanks for putting that together. It's a great resource for the rest of us!--------Glenn ThomasN?????http://www.flyingwood.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 8 Feb 2007 07:04:40 -0800 (PST)
Re: Pietenpol-List: Several ?? on this Pietenpol I just bought.
Original Posted By: "Ed G."
Gus,All bolts should be AN type with self locking nutsNylon insert type nut for non moving parts.Castle nuts with cotter pin where the bolt acts as a hinge pin or in hightemperature areas (under the cowling)No regular nuts should be used.On the VW conversion:Since you did not indicate that it has flown with the VW, I stronglyrecommend to do a Weight and Balance first !The VW should be considerably lighter.I personally doubt the VW is a strong enough engine for the Pietenpol, butI leave that up to you.Most importantly it needs to be a balanced plane.As it is an experimental Airplane there is no need to get an AI involved.An A&P can do the AI's job.However when a different engine is installed you do have to go through thefly-off period againThis applies when you swap the C 65 with a VWit does not apply if you swap a C 65 with another C 65Fly off period for a automotive engine powered aircraft is 40 hours with acertified aircraft engine it is 25 hours.Within that 40 hours no passengers are allowed and all flights can notextend beyond a 20 mile radius of home field.20 miles is typical, you can negotiate more with the FAA.You will have to notify the FAA that engines have been replaced unless theprevious owner did that.As a general statement as this is your first experimental, I recommend youcontact a local EAA tech counselor and let them have a look at it.The EAA tech counselors are volunteers and it is free of charge (OK, maybesome coffee and donuts)Hans gus notti To Sent by: pietenpol-list(at)matronics.com owner-pietenpol-l cc ist-server@matron ics.com Subject Pietenpol-List: Several ?? on this Pietenpol I just bought. 02/08/2007 09:04 AM Please respond to pietenpol-list@ma tronics.com Hello all,OK I have a few questions on how the steel bellcranks are attached to thewood.Less start with the rudder bellcrank, (I can take pictures next week ifneeded), The bellcrank for the rudder is lose due to the 2 small bolts thathold it to the wood ( the wood running from the top of the rudder to thebottom up front) on the rudder came loose after only 25 hours of flying. Ican snug the 2 bolts down and tighten them up with no problems, however Ican see these working loose again, thread lock wold most likely stop this.My question is, are these 2 little bolts the only attachments to therudder? The rudder is built solid, so I'm not concerned about that.2). The bellcranks for the elevator I see they are attached with 3 bolts. 1upfront going through the front leading edge of the elevator, with 2 boldsbolted through a peice of wood about 1/3 way back from the leading edge ofthe elevator. My question here is does thissound properly attached?One more quick one, I have allways been a production flying clown, this ismy 1st journey with a homebuilt, here's the scope on it. It was built in1991 has flown off the 25hours, it has a N #, the 25 hours was flown with aC65 for the motor, in 1994 they replaced the c65 with a VW conversion1835cc. Now the way I understand it that's a major modifcation.So what do I need to do? After I have it back in airworthy condition do Ihave to have an AI inspect it? What else?Thanks,GusIf this makes any since please let me know..... TV dinner still cooling?Check out "Tonight's Picks" on Yahoo! TV.________________________________________________________________________________
Re: Pietenpol-List: great evening viewing
Hi Gus...The rudder horn should have three bolts. There should be a steel piece aproxamately 5/8" wide that is welded into the back edge of the rudder horn and bolted into the center spar of the rudder with one bolt. I can see that if it is not there there would be alot of twisting force on the front two bolts and a risk of wringing the leading edge out of the rudder. That's if I'm understanding what your trying to say of course. Ed G.>From: gus notti >Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: Several ?? on this Pietenpol I just bought.>Date: Thu, 8 Feb 2007 07:04:40 -0800 (PST)>>Hello all,>> OK I have a few questions on how the steel bellcranks are attached to >the wood.>> Less start with the rudder bellcrank, (I can take pictures next week if >needed), The bellcrank for the rudder is lose due to the 2 small bolts that >hold it to the wood ( the wood running from the top of the rudder to the >bottom up front) on the rudder came loose after only 25 hours of flying. I >can snug the 2 bolts down and tighten them up with no problems, however I >can see these working loose again, thread lock wold most likely stop this. >My question is, are these 2 little bolts the only attachments to the >rudder? The rudder is built solid, so I'm not concerned about that.> 2). The bellcranks for the elevator I see they are attached with 3 >bolts. 1 upfront going through the front leading edge of the elevator, with >2 bolds bolted through a peice of wood about 1/3 way back from the leading >edge of the elevator. My question here is does this> sound properly attached?>> One more quick one, I have allways been a production flying clown, this >is my 1st journey with a homebuilt, here's the scope on it. It was built in >1991 has flown off the 25hours, it has a N #, the 25 hours was flown with a >C65 for the motor, in 1994 they replaced the c65 with a VW conversion >1835cc. Now the way I understand it that's a major modifcation.> So what do I need to do? After I have it back in airworthy condition do >I have to have an AI inspect it? What else?>> Thanks,>> Gus>> If this makes any since please let me know.....>>>--------------------------------->TV dinner still cooling?>Check out "Tonight's Picks" on Yahoo! TV.________________________________________________________________________________Subject: Re: Pietenpol-List: great evening viewing
