Original Posted By: "Dan Loegering"
Pietenpol-List: Fuse assembly question
RE: Pietenpol-List: Fuse assembly question
Dan,Jacks correct, doesnt make any difference. Mine are in the X shape. Checkout http://www.cpc-world.com for some pictures.CheersPeterWonthaggi Australiahttp://www.cpc-world.com-----Original Message-----
Original Posted By:> Dan Loegering
Dan I thing you have it reversed.If we are looking at the same thing.The top brace should go from the front left to the rear right.The bottom brace should go from the front right to the rear left.The bottom sketch is from the bottom of the plane. Dale MPLS> [Original Message]
Re: Pietenpol-List: Cutting the Toilet Paper
Subject: Re: Pietenpol-List: Cutting the Toilet Paper In a message dated 2/22/2007 7:36:17 AM Central Standard Time, michael.d.cuy(at)nasa.gov writes:That was some good video, Chuck. Thanks for posting that and letting us fly thru the flight with you. Great fun that is. Haveyou given crepe paper rolls a try yet ? The Dollar Store or Wal Mart has those rolls at reasonable prices. Catch them outside ofyour prop about mid-wing on each side and then fly around town with them. I've found there is a Vncp (velocity never exceed whiledragging crepe paper around) because it will stretch to a point then break if you go too fast. Mike C.Hey Mikee,I haven't tried the crepe paper yet, so it is on my 'to do' list this summer. I'll just have to keep 'er below the Vnewdcpa speed. Question: Would a slip, slide the crepe paper off the wing ? Would a slip in the other direction slide the crepe paper closer to the center ? Come to think of it, it would probably make a pretty good Angle of Attack Indicator !!I'm gonna have to get some video of that !!Check list for Dollor Store :Ten Bottles of Baby OilTen rolls of Crepe paperChuck G.________________________________________________________________________________Date: Fri, 23 Feb 2007 15:26:40 -0800 (PST)
> Subject: Pietenpol-List: Fuse assembly question>>> Ok all you guys that have been here before, Just need a quick bit ofclarification. >> When looking from the top of your fuselage as you were assembling, thediagonal cross members should form an "X" correct? Example: the top piecediagonals from upper right to lower left, and the bottom piece diagonalsfrom upper left to lower right... >> I know, simple question, but long evening hours and looking at too manyplans sets have temporarily fried my brain.>> Thanks!>> Dan Loegering> Fargo, ND>>________________________________________________________________________________
