Hello,I am new to the list and would like to build a Peitenpol. I am looking for a set of plans if anyone has an unused set or the address where I can order a set if they are still available.Thanks,Max ________________________________________________________________________________Date: Thu, 22 Mar 2007 22:57:16 -0300 (ART)
Pietenpol-List: New to the list...
Re: Pietenpol-List: New to the list...
Original Posted By:> "Max Hegler"
Welcome to the list, Max. Plans are still available from the Pietenpol family.Here is their website:http://www.pressenter.com/~apietenp/There is quite a bit of information available there, and tons of stuff availablein the archives of this listBen CharvetMims, Fl>
Original Posted By: "Max Hegler"
Hello Max,Welcome to the list. Not sure if you've ever seen a Piet up close but it reallyhelps get you motivated! There are Piets all over the country, where are youfrom? You may have someone close by that you could visit.Don EmchNX899DERead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Re: New to the list...
Hello Don,I live just west of Columbia, TN. I have actually been looking at Pietenpols since the early 60's. Just took retirement to get me to started.Thanks,Max----- Original Message -----
Ben,Thanks!MaxWilliamsport, TN----- Original Message -----
Hi MaxPlans can be purchased from Donald Pietenpol 1604 Meadow Cr. Rochester, Mn. 55904Try using Google and type in Donald Pietenpol and check out his web site. A couple of things you may want to think about before ordering plans. Have you thought about what type of engine you would like to use? If A-65 or Corvair, you will need long fuse supplement plan, if Model A, short fuse. One piece wing or 3 piece wing? If 3, you will need that supplement.You will be able to find lots of help in this group.Dick N.St. Paul, Mn.----- Original Message -----
Max:check ebay right now there is a set listed under aircraft/plansyou may also want to look under projects ast there is a a nice steel barefuse project for sale quite reasonably priced.michael----- Original Message -----
> To: > Subject: Pietenpol-List: New to the list...> > > Hello,> I am new to the list and would like to build a Peitenpol. I am looking for > a set of plans if anyone has an unused set or the address where I can order > a set if they are still available.> > Thanks,> Max > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: New to the list...
>> To: >> Subject: Pietenpol-List: New to the list...>>>>>> Hello,>> I am new to the list and would like to build a Peitenpol. I am looking >> for>> a set of plans if anyone has an unused set or the address where I can >> order>> a set if they are still available.>>>> Thanks,>> Max>>>>>>>>>>>>> ________________________________________________________________________________
