Subject: Pietenpol-List: Hurst Airheart brake master cylinder, HELPGentlemen,I hope this finds you all well! The weather in North Texas is great for flying this weekend. I saw a polished aluminum B-25 fly over my house yesterday.Does anyone know where I can get a repair kit for one of these (please see enclosed)? I think these were sold for racing go-carts or something. I foundthem in a VP-2 (Volksplane) that was built in 1974. We're going to have to start over if I cant find a way/source to rebuild them soon...Thanks in advance guys,Max L. DavisArlington, TX.NX101XW (Reserved)************************************** See what's free at http://www.aol.com.________________________________________________________________________________Date: Sun, 01 Apr 2007 10:04:12 -0400
Re: Pietenpol-List: Hurst Airheart brake master cylinder, HELP
Original Posted By: "Wayne E. Bressler Jr."
Subject: Re: Pietenpol-List: Hurst Airheart brake master cylinder, HELPI've seen similar master cyl's on go-carts. Try a go cart shop. Leon S.in Ks.________________________________________________________________________________Date: Sun, 01 Apr 2007 10:24:26 -0400
Original Posted By: Andimaxd(at)aol.com
I have one in my shop somewhere. If I can find it I'll see if it's any good. Something tells me it works fine. I'll sell it for cheap.DJ ----- Original Message -----
Re: Pietenpol-List: 2.9 Gram Pietenpol Model for Indoor Flight!
Original Posted By: Larry Rice
that was very cool! I've seen non flying models that small made from printed posterboard but the foam trick is definatley cool!DJ________________________________________________________________________________Date: Sun, 01 Apr 2007 13:06:35 -0400
Subject: Pietenpol-List: Hurst Airheart brake master cylinder, HELPHi Max,Last year I purchased a Pazmany PL4 that was built in 1977 and never flown. It has the Hurst-Airheart brakes on it. The parts are a bit pricey. Be sure to order the correct material. They sell 2 kinds of seals, one for mineraloil and one for auto brake fluid.After a lot of searching I found the supplier in Minnesota. The company is: Tol-O-Matic, Inc. 3800 County Road 116 Hamel, MN 55340 Phone 763-478-8000, 800-328-2178 Fax 763-478-8080 Web Site: _www.tolomatic.com_ (http://www.tolomatic.com) email: _sales(at)tolomatic.com_ (mailto:sales(at)tolomatic.com) All the best,Mitch GarnerRV-4, PL-4************************************** See what's free at http://www.aol.com.________________________________________________________________________________Date: Mon, 2 Apr 2007 06:45:08 -0700
Re: Pietenpol-List: Wing weight
Original Posted By: Thomas Bernie
Hello everyone! I am a bit of a lurker but I saw something about NOT usingthe Full Size rib template?I have a full set of ribs made to the full size copy you can buy with theplans. Can someone let me know what the concern was / is?Best Regards,DaveFuse about done, almost ready to start wings! _____See what's free at AOL.com .________________________________________________________________________________Subject: Re: Pietenpol-List: Wing weight
Original Posted By: "Terry Hall"
Clif,I laminated 1"x1.5" strips (alternating grain) with West System andadhesive filler. Here is a photo of the rear spar.Tom> > Ah, Right.> What method of lamination did you use?> > Clif> > > > > > >> > Clif,> >> > The Grega modification cad drawings don't call for routing (they specify> > aircraft spruce). Now I wish I had routed or looked into a built up> > spar -- at least my spars are laminated and strong.> >> > Tom> >> >> > Did you rout the spars as per the plans?> >> > Clif> >> > > > > ________________________________________________________________________________
Pietenpol-List: Re: Wing Rib Template Problem?????
Hello Piet flyers in North Texas, and Arkansas (or anywhere)The planning for the 2007 Ada Air Expo is coming along nicely. We are looking forward to another great day with a variety of warbird aircraft, aerobatic performers, static displays, radio controlled model aircraft, AND a sanctioned BBQ cookoff event. I do hope so that some Pietenpols can make the trip. I'm the airshow annoucer, and I would enjoy the chance of talking about your airplane with a captive audience. Check out the updated website: www.adaairexpo.comTerry HallAirport Manager, City of AdaSky Scout builder________________________________________________________________________________Subject: Pietenpol-List: Re: Wing Rib Template Problem?????
Humidity can change the dimensions of the paper. The changes to the scaling ofthe document when it's printed can also have an affect on the accuracy of thedimensions. When I plotted out the points on the jig I built and then comparedto the full-scale rib plan there was a difference of about 3/4" in the length.I used MDF for the jig and haven't seen a noticable change due to humidity.--------Glenn ThomasN?????http://www.flyingwood.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
