Pietenpol-List: Re: A-75 improved rate of climb
Original Posted By: "Brian Kraut"
Well, I haven't actually done a proper empirical test, but my seat-of-the-pantsROC guage tells me it's significantly improved. Loaded to near gross weighton a 90F afternoon with high humidity, she climbs about like she used to solo,well worth the $$ for the prop in terms of get me over that tree at the endof the runway value. First chance we get, my buddy with his C-85 powered Cub and I will square off ina proper rate of climb comparison. I'll bet I can give him a run for his moneynow :-)BTW, she gets a diet of 100LL and the recommended Marvel Mystery Oil. 100LL becauseI've had problems with alcohol and water in the local mogas, and the MMObecause it can't hurt, and lots of folks with more experience than I swear byit. Dave Mordecaiin buggy Panacea, FLNX520SF> Dave,> > I suspect that you'll get a lot of answers. I think that that as long > as you use top oil, change it often, and keep temps in range, then > you'll do fine at anything under redline even for long runs.> > How's your climb rate with the new prop?________________________________________________________________________________
