Had a couple emails for builder's interested in laser method to set the wheel's toe-in. Rather than repeating, thought I'd write up and post as attachment for anyone who may be interested. Hope it's helpful. Gordon________________________________________________________________________________
Pietenpol-List: Technique for setting wheel toe-in
RE: Pietenpol-List: Technique for setting wheel toe-in
Gordon/Hans,Thanks for the info. What/where am I trying to shim? The only way I can seeto adjust things is to get the gas torch out (like Chuck)CheersPeter _____
Re: Pietenpol-List: Technique for setting wheel toe-in
Original Posted By: Peter W Johnson
Sorry 'bout that Peter,I have a cub style type bungeed gear, also Cessna wheels, brakes and axle. I can shim up behind the axle backing plate.Gordon ----- Original Message -----
I don't know about using lasers and such . . . just spin the wheels and make a chalk line on each wheel, then make the distance exactly the same on the front and back of the wheels. Can't get much simpler than that.Gene________________________________________________________________________________
