Pietenpol-List: elevator control question
Pietenpol-List: Re: elevator control question
Original Posted By: "dwilson"
Subject: Pietenpol-List: Get the Lead Out - NOT !!Friends of the Earth want to remove the relativelysmall amounts of lead from all Av gas:http://www.avweb.com/eletter/archives/a ... 96596EPA's Notice of Petition For Rulemaking http://a257.g.akamaitech.net/7/257/2422 ... -22456.htm)public comment by March 17, 2008**************************************Check out AOL's list of 2007's hottest products.(http://money.aol.com/special/hot-produc ... 0000000001)________________________________________________________________________________Subject: Pietenpol-List: Re: elevator control question
RE: Pietenpol-List: Get the Lead Out - NOT !!
I asked this very question of Vi Kapler. Vi stated that the elevator deflectionshould be at least 20 degrees down and 20 degrees up. He also stated that theelevator deflection should never exceed 30 degrees. I consider Vi one of themost knowledgeable experts with regard to the Aircamper. DanRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: RE: Pietenpol-List: Get the Lead Out - NOT !!Date: Wed, 21 Nov 2007 06:57:22 -0500
Speaking hypothetically (based on geometry of the elevator horns and location relative to the pivot point), with 20 degrees of travel up and down the bellcrank connection point will travel 2-1/2" from stop to stop. I measured it on 41CC and I have closer to 3" total travel of the bellcrank.Oscar ZunigaSan Antonio, TXmailto: taildrags@hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Subject: Pietenpol-List: Re: elevator control question
Original Posted By: "Brian Kraut"
During the Broadhead Pietenpol Fly-in last summer Ken Perkins presented a fantasticdemonstration on his method for constructing elevator, aileron, and rudderhorns. He has also devised a method for removing the slack in the elevatorcables. One change that I made to my elevator horns was to lengthen the hornso that both cable connection points are in-line and of equal distance from thepivot point of the elevator hinge. Many Piet builders have also modified thelocation of the elevator bellcrank pivot. DanRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
View The Video
Original Posted By: Ryan Michals
I normally don't pass on emails like this, but this is just about thewildest thing I have ever seen in aviation. Hmmm, where is the closestmountain?Brian KrautEngineering Alternatives, Inc.www.engalt.comSubject: View The Videohttp://www.mindensoaringclub.com/int2/Open the forum and view the videoAnd they say we are crazy for flying airplanes with no engines/propJim & KarenIf flying was the language of man...Soaring would be the poetry________________________________________________________________________________Date: Wed, 21 Nov 2007 20:33:41 -0800 (PST)
Re: Pietenpol-List: Re: elevator control question
Dan,How did Mr. Perkins build the control horns? And how does he get rid of the slack in the cables?Chris TracySacramento, CaWebsite at http://www.WestCoastPiet.com----- Original Message -----
