Original Posted By: "James"
All,After much deliberating this fall, I have decided to sell my Sky Scout project. It will make a great project for someone, but I'm not able to keep it. The project will simply not fit into my future retirement plans.Here are the particulars: Fuselage skeleton of spruce and a/c plywood is complete and almost ready for installation of parts and varnish. Firewall made of galvanized. Torque tube, control stick, rudder bar, tailskid, elevator bellcrank, elevator horn, rudder horns, and some fuselage fittings complete. All welding done by A&P. Vertical stabilizer, horizontal stabilizer, and rudder are built but will require some finish work Engine support bearers are built.Other items include: Misc. aircraft hardware Strips of 4130 steel Steel for axles Rudder and elevator hinges extra 1/4" and 1/8" a/c plywood Full size plans Pietenpol building manual My notes and photos I'm asking $1000 for the complete project. Project is located in Ada, OK, at the munipal airport. I have no way to transport to the new owner.Contact me at adaairport(at)cableone.netThanks,Terry Hall ________________________________________________________________________________
