Pietenpol-List: Better name for "big" piet
RE: Pietenpol-List: Butt rib covering
Subject: RE: Pietenpol-List: Butt rib covering Aye.That is what happened. I glued and nailed it, but after a while it all points of contact between the root-end ribs on both wing panels began a march toward the wingtip. The movement resulted in the 1/16 x 2 inch strip to develop quite a wave at the spar. Very unsightly. I fixed it by adding more glue surface area behind the rib/spar intersection and pulled it tight while the glue set. Fine since.Stevee
HiInstead of oversize Piet, we need a better name to describe the full cut pietenpol.I will suggest a few maybe somebody else has a term that would be better than OVERSIZE.How about- Piet Plus- Piet plus 2- Piet plus 3 etc etc- Supersize Piet- Jumbo PietAnybody else have a suggestion?Steve in Maine________________________________________________________________________________
Re: Pietenpol-List: Better name for "big" piet
Subject: Re: Pietenpol-List: Better name for "big" pietHow bout something we olders dream about " Bigger Pieters "Nathan**************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exer ... __________
Subject: Re: Pietenpol-List: Better name for "big" pietMonster pietePiet a PaloozaPieten BiltPiet a dactyleColossal PietWide flyerPerfect PietPure PietPiet a tudeNothing butt PietNeat PietSweet PietPiet powerPietenpol Air camper 1wide Piet King of skyto name a fewJohnIn a message dated 1/31/2008 1:27:35 P.M. Eastern Standard Time, redsglass(at)hotmail.com writes:HiInstead of oversize Piet, we need a better name to describe the full cut pietenpol.I will suggest a few maybe somebody else has a term that would be better than OVERSIZE.How about- Piet Plus- Piet plus 2- Piet plus 3 etc etc- Supersize Piet- Jumbo PietAnybody else have a suggestion?Steve in Maine(http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exer ... __________
Subject: Re: Pietenpol-List: Better name for "big" pietyou are the man!In a message dated 1/31/2008 2:20:30 P.M. Eastern Standard Time, Isablcorky(at)aol.com writes:How bout something we olders dream about " Bigger Pieters "Nathan____________________________________ Start the year off right. _Easy ways to stay in shape_ (http://body.aol.com/fitness/winter-exer ... 0000002489) in the new year. (http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exer ... __________
RE: Pietenpol-List: Possible engine alternative
http://www.experimental-aviation.com/Co ... _cost.html _____
Re: Pietenpol-List: Possible engine alternative
Original Posted By: Michael Fisher
---------------------------------Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.________________________________________________________________________________Date: Fri, 01 Feb 2008 08:52:16 -0900
