Pietenpol-List: To All the Newbies
Pietenpol-List: Re: To All the Newbies
Original Posted By: "MikeD"
Jack.Phillips(at)cardinal wrote:> I found this on the RV-10 list this morning and thought I'd pass it on.> This is what happens when you let computers control airplanes. Glad I> decided not to put the fly-by-wire and flight control computers in my> Pietenpol.> > Jack Phillips> Shivering in 34 degree rain in North Carolina> > --Oopsy. This happened during a ground run-up. The brakes were full on, then somethinghappened and it broke loose. There were 7-8 test personnel on board anda few were injured. The airplane is a bit messed up!Mike--------Piet-builder-who-hopes-to-be-flying-next-summerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: To All the Newbies
[quote="kmheidecpo(at)yahoo.com"]Fellow Pieters: Does fiberglass deteriorate in gas after time? Specifically a fiberglass rodsuch as a driveway marker? Ken H Be a better friend, newshound, and > The key is the resin system. Fiberglass is just that - fiberglass - and it is veyresistant to most chemicals. The choice of resin binder system is what determineschemical compatibilty in a composite material. There are several choices- epoxy, vinyl ester, polyester, melamine, thermoplastics... the list goes on,all depends on the product. You would have to test. If in doubt and you wanta rod for a specific purpose I'd suggest McMaster Carr or some other place soyou can buy something that can be identified.Amsafetyc - what do you mean you doubt it is even gas after 45 days...? Ethanolor methanol and gasoline are compatible and don't react. If they did there wouldbe quite a few consumer warnings to drain auto gas tanks and not to storelawnmower gas for longer than a month.Mike--------Piet-builder-who-hopes-to-be-flying-next-summerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: To All the Newbies
I just cleaned all the garbage out of that list 2 days ago and it's back again!I'm going to use the snow excuse to get out of work early today and fix that problemonce and for all. The real problem is that I tried to make things easilyaccessible so you wouldn't need an id and password. I'll have to lock it downand release a general id and password to the whole list. Maybe while I'm atit I'll add in different options for sorting the list and a search so you canfind people by name/location.--------Glenn ThomasN?????http://www.flyingwood.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: To All the Newbies
To add to Bill's list, check out Chris Tracy's website atwww.westcoastpiet.comLots of pictures and info, including alternative spar information.Greg C. ----- Original Message -----
Re: Pietenpol-List: Control question
On NX18235 the rudder stops are placed so the rudder won't hit the elevator.Aileron stops are installed but are pointless since the stick hits my legs before the stops.No elevator stops installed.I know you asked for measurements but since no two are built alike.....Greg C. ----- Original Message -----
