Pietenpol-List: Continental engine drawing file
Original Posted By: bcharvet(at)bellsouth.net
Hi folks,I've hunted around but so far no luck. Does anyone know if and where I could scama CAD file for a Continental A-65 or A-75? I don't need great detail, but thebasic views that will give me footprint, mounting points, prop hub locationetc.. IOW what you would need to design an engine mount and sketch a cowl around.Thanks!Mike--------Piet-builder-who-hopes-to-be-flying-next-summerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Continental engine drawing file
The dimensions for the motor mounts were posted a few weeks ago. I was lucky enoughto have someone give me an old crankcase that as cracked, and I used thatto mock-up my cowling. Another benefit of EAA membership! Ben-------------- Original message from "MikeD" : --------------> > Hi folks, > > I've hunted around but so far no luck. Does anyone know if and where I could> scam a CAD file for a Continental A-65 or A-75? I don't need great detail, but> the basic views that will give me footprint, mounting points, prop hub location> etc.. IOW what you would need to design an engine mount and sketch a cowl > around. > > Thanks! > > Mike > > -------- > Piet-builder-who-hopes-to-be-flying-next-summer > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.p ... 133#166133 > > > > > > > > > > The dimensions for the motor mounts were posted a few weeks ago. I waslucky enough to have someone give me an old crankcase that as cracked, and Iused that to mock-up my cowling. Another benefit of EAA membership! Ben-------------- Original message from "MikeD" <mjdt@auracom.com>: -------------- > --> Pietenpol-List message posted by: "MikeD" > > Hi folks, > > I've hunted around but so far no luck. Does anyone know if and where I could > scam a CAD file for a Continental A-65 or A-75? I don't need great detail, but > the basic views that will give me footprint, mounting points, prop hub location > etc.. IOW what you would need to design an engine mount and sketch a cowl > around. > > Thanks! > > Mike > > -------- > Piet-builder-who-hopes-to-be-flying-next-summer > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.p ... 133#166133 > > > > > > > > > ________________________________________________________________________________Date: Mon, 25 Feb 2008 11:33:20 -0800 (PST)
Pietenpol-List: Re: Continental engine drawing file
Original Posted By: "DAVE CATES"
bcharvet(at)bellsouth.net wrote:> The dimensions for the motor mounts were posted a few weeks ago. I was luckyenough to have someone give me an old crankcase that as cracked, and I used thatto mock-up my cowling. Another benefit of EAA membership! > Ben> [Embarassed] Come to think of it, I don't recall searching THIS forum for motormount info. Shame on me. I'll see if I can find that.Still, it would still be cool if I could save myself the work of measuring anddrawing the engine. I do want to have a drawing of it on hand.Thanks..Mike--------Piet-builder-who-hopes-to-be-flying-next-summerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By: Grover Summers
Original Posted By: "MikeD"
While it is true that the strength of a laminated wooden structural member is always limited by the strength of the wood itself, the likelihood of having hidden defects is appreciably reduced when smaller sections are glued together. Ergo, a laminated member can be stronger than a one-piece solid one.Also, select pieces can be placed at the top and bottom of a wing spar, or beam, where the stress is greatest and lesser quality material can be placed in between. My 1946 Taylorcraft had laminated spars and this is exactly what they did in those days when so many lightplanes were being built. In addition, there were beautifully-done scarf joints (without doublers!) indicating the use of precision machinery.I don't own that T'Craft anymore, but 62 years later it still has the same spars with the factory splices. A testimonial to laminating and perfect glue joints, to be sure.On my Pietenpol I used Douglas Fir for the wing spars, duplicating the original I - beam section by laminating 1/4 inch flange strips to a full-depth web that is 1/2 inch thick. "Swallow tail" filler blocks were used at fitting locations. There are no splices. Perhaps I could have reduced the cross section size to take into account the greater strength of DF (as compared to spruce) in order to save some weight, but I didn't. Even so, my Piet is lighter than some at 630# dry empty weight.BHP told me that he laminated the spars of the last airplanes he built. I think he used Western Hemlock strips to make a rectangular cross section. The only disadvantage of laminating, as I see it, is the extra work involved.Graham Hansen Pietenpol CF-AUN ________________________________________________________________________________Subject: Pietenpol-List: Re: Continental engine drawing file
I just looked through my resource files and located the 3-views of the small Continentals.One of the few times that Bingelis let me down... he doesn't have3-views of the Continentals that we want. However, Evans does have a rudimentary3-view with key dimensions in his "Lightplane Designer's Handbook".I would be happy to scan that one to a .jpg and upload it to my website and willdo so in the morning when I get time. I trust that Mr. Evans will not mindme putting it out on my site, particularly since I would encourage anyone topurchase his fine manual... it is a close second to Bingelis' books in utilityand chock-full of useful information of every sort.Being from the old school, I had much rather look at hand-drawn line illustrationsthan all the CAD drawings in the world. Another reason why I so enjoyed purchasingBill Rewey's packet of tips and ideas that he publishes for sale; theyare all hand-drawn. They all make great armchair reading and thinking material.Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
RE: Pietenpol-List: Continental engine drawing file
Can this be converted into a graphic file like a jpeg? I don't use CADsoftware, but am curious what this would look like.Rob in Anchorage, AK-----Original Message-----
Rob,How about a PDF file?I just took the Autocad file of the C90 Grover posted, and converted it toPDF.Unfortunately there weren't any dimensions on the Autocad drawing, so I'mnot sure what use this will be.Anyway, here it is...Bill C. _____
RE: Polyurethane glues (Was: Re: Pietenpol-List: Re: Spruce Alternatives)
I believe that the study you are referring to was in one of the wood workingmagazines. I believe it was Mark Langford that posted a copy of the articleor a link to it. I am up to my neck right now and can't look for it, but itmight be found on www.krnet.org.Oscar, do you still have that email somewhere handy?Brian KrautEngineering Alternatives, Inc.www.engalt.com-----Original Message-----
I've scanned the dimensioned 3-view drawing of the small Continental engine from Evans' manual to a .jpg and it can be viewed here: http://www.flysquirrel.net/piets/3view.jpg . If you want to snag it, just right-click on the image and 'save as'.I once again recommend Evans' book as being well worth the money, and in fact if you purchase Volksplane plans from him, he will throw in the designer's manual for free. You can order here: http://www.evansair.com/handbook.htmOscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
Re: Polyurethane glues (Was: Re: Pietenpol-List: Re: Spruce Alternatives)
Hi,It's been quite a while since I posted anything to the list, largely because my project is dormant while I search for a better job. Anyway, I've used both Gorilla Glue and the Elmer's equivalent in a number of (non-aircraft) applications over the years & I think it has good potential for some aircraft applications if you use it correctly. I did some bond tests several years ago & got wood failure before glue failure every time if I used the following procedures:- Used a freshly-opened bottle of glue (no more than 2 weeks old). This is very important, even in the bottle, these glues thicken appreciably with age & I'm sure bonding strength is compromised.-Spread a 'wetting' layer of glue on both surfaces & let it soak in for about a minute (but not too long - foaming BAD)- Used moderate clamping pressure to assure a tight joint, but not enough pressure to starve the joint.This procedure results in good joint & as I said, destructive testing always resulted in wood failure, not the glue. Given all this, I plan on using Gorilla glue on my Piet wherever I do not have to rely on it as a structural agent, although I suspect I could. It does great for laminations, and eliminates all the mixing & curing issues that go with T-88 or resorcinol. And, unlike the Titebond glues, it is waterproof when cured (I glued up a sandbox with it 5 years ago & despite year-round exposure to the elements, the glue had not yet failed as of last Fall - don't ask me t5o go check now, there's 6 inches of snow on the ground & more coming down).As with anything else, all the usual disclaimers apply to the above statements - I'm statisfied with how Gorilla glue works for me - your mileage may vary.Kip GardnerOn Feb 26, 2008, at 4:41 PM, Owen Davies wrote:> >> Ryan Mueller wrote:>> I understand the desire to want to be able to get what you need >> when you want it. Been there, done that, living it.
>>>> However, choosing to use a glue other than what are the generally >> accepted norms just because it's readily available at the local >> store, to me, is not the right reason.> Sounds like I didn't put the emphasis quite where it belonged.>> My desire to use a locally available glue does not truly stem from > scheduling concerns. That was only a feeble attempt to justify in > my own mind what really amounts to being a low-grade crank.>> The truth is that I wish to find a locally available glue that is > fully suitable for aircraft use because that is my idea of how life > ought to be. St. Bernie didn't order from Aircraft Spruce when he > wanted to build an airplane. He searched out materials he could buy > locally and used them. I would prefer to do the same.>> Now, I recognize that this is no longer the late 1920s. Before > there was Windows, or DOS, or even CP/M, I was the first kid on my > block to own a computer. I have earned most of my living for the > last 20 years predicting will happen over the next decade or two-- > on rare occasions longer--in subjects from technology to terrorism > for major corporations, industry and professional organizations, > and the occasional government agency. I'm darned good at accepting > the present and looking forward rather than back.>> Yet my sense of what is right and fittin' calls for a Piet (or most > other non-plastic airplanes) to be built insofar as possible from > locally available materials using technologies a bright farm kid 80 > years ago would have mastered in his teens. If that means ignoring > "the generally accepted norms," well, the first guy who used T-88 > instead of resorcinol seems to have gotten away with it. So watch > out for falling chips. But don't worry about falling airplanes. I > meant that part about "fully suitable for aircraft use" every bit > as seriously as the rest of this mini-manifesto.>> Owen>>________________________________________________________________________________Date: Tue, 26 Feb 2008 19:31:26 -0500
taildrags(at)hotmail.com wrote:> I've scanned the dimensioned 3-view drawing of the small Continental engine from Evans' manual to a .jpg and it can be viewed here: http://www.flysquirrel.net/piets/3view.jpg . If you want to snag it, just right-click on the image and 'save as'.Cool! Got it, thanks.Mike--------Piet-builder-who-hopes-to-be-flying-next-summerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Hey thanks Steve. I have saved this to see what I can do with a cowling. Iplan on using the Corvair with the longer fuselage. But your suggestions aregood and I will search for a program, and then hit the list with a requestfor a cad file of the corvair engine. I bet William Wynne will have one.Regards,RobCheck out our EAA chapter website to get the news from the North.www.eaa42.org, soon I will be putting up a website with Alaska Pientenpolprojects, so keep an eye out for it this month.RS-----Original Message-----
Rob,I can't remember where I got this from, but attached is a JPEG of an Autocaddrawing of the corvair engine, as well as the DWG file.Bill C. ________________________________________________________________________________Date: Thu, 28 Feb 2008 13:30:42 -0800 (PST)
RE: Pietenpol-List: Power setting question.
Tim,I have 100hp (ish) on my Corvair powered Piet and it is always full power ontake off. As Harvey says, you can always pull it back a bit when safely onyour way.CheersPeterWonthaggi Australiahttp://www.cpc-world.com-----Original Message-----
Full power setting enriches the mixture to prevent detonation.Dick Bakerwww.aerovisiontech.com-----Original Message-----
Pietenpol-List: Re: Fuel Sending Ideas
waltdak(at)verizon.net wrote:> I haven't read all the posts on this thread, but would it help if I scanned > the dimentional drawing from the Continental manual?> walt evans> NX140DL> > "No one ever learned anything by talking"> Ben Franklin> ---Hi Walt,If you mean would it help me (the thread starter) or one of the other folks inhere? If me, I have access to manuals, that's no prob, but thanks. My originalquest was to beg a copy of a CAD drawing of a small Continental, figuring someoneout these must have one somewhere. Mind you, I'm not sure how many Piet enthusiastsalso spend their time designing other aircraft on CAD. Kind of a nichewithin a niche, cuts down on the likelihood a bit I guess!Mike--------Piet-builder-who-hopes-to-be-flying-next-summerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Fuel Sending Ideas
kmheidecpo(at)yahoo.com wrote:> Fellow Pieter's.....> > Or should I say Pieter fellows?...either way, here is some of the hardwareand results of building and testing for a new fuel sight gauge on my tank. Remember,this is a test sample to see what works...this is a "professional" pleasedo not attempt to preform this at home or in your work shop! tee-hee-hee> > I started with a bunch of items from the local hardware store. After creatinga vision, I narrowed it down to the aluminum driveway marker, copper waterknocker, a few copper reducers and two brass sleeves to provide a smooth insidesurface to work with.> > I tested this in a bucket of water and found the small aluminum canister ofAxe works great but not strong enough for my liking. Therefore, I have createdanother aluminum shaft with a 2oz can of WD-40 (not yet finished). After drainingthe contents, drilling, and epoxy the aluminum shaft in place, this setup works very nice. No binding and smooth shaft movement...> > Anyone else experiment with tank gages other than the wire. With my eyesight,The red cap is easily seen from a distance and the gauge hole is slightly offcenter so I can see the gauge when a passenger is in the front cockpit. OnceI have tested this system further, I'll show a photo of the whole gauge in thetank.> > Thoughts or opinions? I have more photos if interested...> > Kenneth M. Heide, BA, CPO, FAAOP> > I can't figure out how you get the float into the tank.. [Question]--------Piet-builder-who-hopes-to-be-flying-next-summerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 28 Feb 2008 16:59:46 -0800 (PST)
RE: Pietenpol-List: Continental engine drawing fileFor those of us running older versions of AutoCad, a .dxf file would be much more useful than the .dwg created by the newer versions. .dxf is a quick and easy export conversion. ----- Original Message -----
