Pietenpol-List: 3' Center Section
Those who are increasing the center section to 3', are you diminishing thewings by a like amount? Does anyone have a flying example of a 3 piece wingwith a 3' center section?Gary Boothe Cool, CA WW Conversion 90% done, Working on Tail Group (and ribs) _____
RE: Pietenpol-List: 3' Center Section
Subject: RE: Pietenpol-List: 3' Center SectionNot that I know of, but I built mine with a 4' center section with vertical cabanes. I did take off the amount of wing panels to get the same wingspan.Flies fine. Larger center section gave a slight increase in fuel capacity. ~14gallons.Stevee
Gary,Bill Rewey's NX17WR has a three-foot center section. It flies (a lot). Idon't know whether he shortened the outboard wing panels or not.Here's a link to a photo of his center-section:http://www.westcoastpiet.com/images/Bil ... 05.JPGBill C. _____
Re: Pietenpol-List: 3' Center Section
My Piet, NX20795, and Bill Rewey's Piet have 3 ft. center sections with total wing span of 30 ft. Bill has logged over 30,000 mi. over the last 18 yrs.Roman BukoltOn Mar 23, 2008, at 8:17 PM, Gary Boothe wrote:> Those who are increasing the center section to 3=92, are you > diminishing the wings by a like amount? Does anyone have a flying > example of a 3 piece wing with a 3=92 center section?> Gary Boothe> Cool, CA> WW Conversion 90% done,> Working on Tail Group (and ribs)>
> Re: Pietenpol-List: 1st rib
RE: Pietenpol-List: A New Person
So far I have come up with Bill Rewey, Jack Phillips and Roman Bukolt. Theremay be more, but that's all I know of for now. The pro's seem to all beabout increasing the center section tank size, primarily. Size range from30", 36" and 48".Does anyone care to express any concerns or cautions?Gary Boothe Cool, CA WW Conversion 90% done, Working on Tail Group _____
Original Posted By: Gary
To:Subject: Re: Pietenpol-List: 3' Center SectionMe too. I have a 37" center section and I copied Jack's cut out for radios. I mademy wings to plan. Dick N. ----- Original Message -----
Re: Pietenpol-List: A New Person
Jack, many thanks for the speed info. I especially enjoued the gliding discussion!Where are you located?You can call me Jim. My wife is Debbie MorrowJim Lagowski, NX221PT----- Original Message -----
Me too. I have a 37" center section and I copied Jack's cut out for radios. I made my wings to plan.Dick N. ----- Original Message -----
Original Posted By: "=?utf-8?B?Sm9obiBSZWNpbmU=?="
$5,000 w/o engine, 8 withRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: 3' Center Section
Just curious as to how that may impact the wing loading especially since it increasesoverall square footage of wing surfaceHas anyone done the calculations?Or is it an even tradeoff?JohnSent from my Verizon Wireless BlackBerry-----Original Message-----
Hi Jack...I had thought about putting my radio in the centersection of my Piet a long time ago but decided that reaching up into the wind stream would make it difficult if not impossible to change stations etc. My Piet is not flying yet and I am still toying with the idea so I thought I would ask someone with first hand experience if it is a problem or not. Sooo...Is the wind a problem when adjusting your radio??? Will you be at Sun N Fun this year???...Ed Grentzer West coast Fl.>From: "Phillips, Jack" >Reply-To: pietenpol-list(at)matronics.com>To: >Subject: RE: Pietenpol-List: 3' Center Section>Date: Tue, 25 Mar 2008 07:19:10 -0400>>>>The extra 6" of span my centersection added just about cancelled the area I >lost by adding a circular cutout to the centersection. But I don't think a >little more wing area could possibly hurt, and it certainly would help the >climb rate.>>Jack Phillips>NX899JP>>>-----Original Message----->From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Recine>Sent: Monday, March 24, 2008 11:12 PM>To: pietenpol-list(at)matronics.com>Subject: Re: Pietenpol-List: 3' Center Section>>>>Just curious as to how that may impact the wing loading especially since it >increases overall square footage of wing surface>>Has anyone done the calculations?>>Or is it an even tradeoff?>>John>Sent from my Verizon Wireless BlackBerry>>-----Original Message----->From: "Dick Navratil" >>Date: Mon, 24 Mar 2008 21:52:02>To:>Subject: Re: Pietenpol-List: 3' Center Section>>>Me too. I have a 37" center section and I copied Jack's cut out for >radios. I made my wings to plan.>Dick N.>----- Original Message ----->From: Gary> Boothe >To: pietenpol-list(at)matronics.com >Sent: Monday, March 24, 2008 10:58 AM>Subject: RE: Pietenpol-List: 3' Center Section>>>So far I have come up with Bill Rewey, Jack Phillips and Roman Bukolt. >There may be more, but that's all I know of for now. The pro's seem to all >be about increasing the center section tank size, primarily. Size range >from 30", 36" and 48".>>Does anyone care to express any concerns or cautions?>>Gary Boothe>Cool, CA>WW Conversion 90% done,>Working on Tail Group>>>---------------->>From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick >Holland>Sent: Monday, March 24, 2008 8:45 AM>To: pietenpol-list(at)matronics.com>Subject: Re: Pietenpol-List: 3' Center Section>>Bill Rewey's Piet has that setup and has been flying for at least a decade.>>Rick>>On Sun, Mar 23, 2008 at 7:17 PM, Gary Boothe > wrote:>>>Those who are increasing the center section to 3', are you diminishing the >wings by a like amount? Does anyone have a flying example of a 3 piece wing >with a 3' center section?>>Gary Boothe>Cool, CA>WW Conversion 90% done,>Working on Tail Group (and ribs)>>>---------------->>From: owner-pietenpol-list-server(at)matronics.com > >[mailto:owner-pietenpol-list-server(at)matronics.com > ] On Behalf Of Clif >Dawson>Sent: Saturday, March 22, 2008 11:10 PM>To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: 1st rib>>>That's just about where I am, started and finished the tailfeathers in >2000.>>Now here it is, 2008 and 740 hours later. I'm working on my 3 ft center>>section now. It's mounted but will be off again for tank fitting and >installation,>>ply covering, etc.>>>This thing sure does look different with it sitting up there!.I keep >promising>>myself I'll take pictures but I seem to spend that time making engine >noises. :-)>>>Clif>>>"So many worlds, so much to do, so little done, such things to be." ~ Lord >Alfred Tennyson>>----- Original Message ----->>From: HelsperSew(at)aol.com >>To: pietenpol-list(at)matronics.com >>Sent: Saturday, March 22, 2008 4:59 AM>>Subject: Re: Pietenpol-List: 1st rib>>>Congratulations Gary!! Now you are on your way to a wonderful experience. >I am 8 years and counting. Hopefully you will finish sooner.>>>Dan Helsper>Poplar Grove, IL.>>>---------------->>Create a Home Theater Like the Pros. Watch the video on AOL> Home > >.href="http://www.matronics.com/Navigator?Pietenpol-List > >">http://www.matronics.com/Navigator?Pietenpol-List > >href="http://forums.matronics.com >">http://forums.matronics.com >href="http://www.matronics.com/contribution > ">http://www.matronics.com/c >>>---------------->>3/22/2008 4:43 PMhttp://www.matronics.com/contribution > >>>-->Rick Holland>>>_________________________________________________>>or otherwise private information. If you have received it in error, please >notify the sender>>Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - >Norsk - Portuguese>>________________________________________________________________________________Subject: RE: Pietenpol-List: 3' Center SectionDate: Tue, 25 Mar 2008 09:25:04 -0400
