Pietenpol-List: Which Locktite to use?
Subject: Pietenpol-List: Which Locktite to use?Gentlemen,My prop hub will hang on to the Ford A engine by only 4 bolts and there is not enough room on the back side for any nut at all. Which Locktite product would you use to make sure those bolts never got loose? I need recommendationsfrom some experts. Dan HelsperPoplar Grove, IL.**************Create a Home Theater Like the Pros. Watch the video on AOL Home. (http://home.aol.com/diy/home-improvemen ... 0000000001)________________________________________________________________________________
RE: Pietenpol-List: Which Locktite to use?
Subject: Re: Pietenpol-List: Dodging church steeples in IndianaGiven that the Piet is a "low and slow" airplane, what can be done to get the rate of climb in the 500-600 range at gross?Boyce**************Create a Home Theater Like the Pros. Watch the video on AOL Home. (http://home.aol.com/diy/home-improvemen ... 0000000001)________________________________________________________________________________Subject: RE: Pietenpol-List: Which Locktite to use?Date: Tue, 1 Apr 2008 08:35:15 -0400
Re: Pietenpol-List: Which Locktite to use?
