Pietenpol-List: Aerial plans - was Are you guys scarfing 1/16th inch
Jim,It sounds as though the construction of the Aerial wing rib is differentfrom the Pietenpol rib. Surely the plans must indicate the extent of theleading edge wrap. There aren't many of us out here that have even seen ChadWille's plans, so it would be a challenge to offer advice on this matter.Many people comment that the original Pietenpol plans seem to be missing alot of information, but when you look very closely, you find that verylittle is actually missing (Granted, a few more details would be nice). Takea closer look at the plans, and see if the missing info suddenly appears. Ifyou could scan (or photograph) the part of the drawings in question, andpost them here on the list, maybe someone could advise the best route. Ormaybe you need to have your EAA technical counsellor look over your plansand see if the info really isn't there. On second thought, maybe that's yourbest plan.Bill C.-----Original Message-----
