Pietenpol-List: Vicksburg, MS
Anyone in the Vicksburg, MS area that has or is building a Piet. If so I would like to take a look see the week of the 25th. Please drop me a note and lets see if we can get togeather.Chet________________________________________________________________________________
Re: Pietenpol-List: My Piet has wings!
Subject: Re: Pietenpol-List: My Piet has wings!Ben,Congratulations on your milestone!! How sweet it is to finally see an airplane!! I know the feeling, as I was at your stage last November. Keep going!!Dan HelsperPoplar Grove, IL.**************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-Volkswagen-Je ... 0000000007 )________________________________________________________________________________Date: Sun, 17 Aug 2008 17:43:14 -0700 (PDT)
Pietenpol-List: Re: My Piet has wings!
Original Posted By: "Joser"
yes it does help-thanks.I will start trying to frame the inspection area in tomorrow.doyou sleeve the pins on the master link with short pieces of tubing orjust let the cable thimble ride on the pins?RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: My Piet has wings!
Great Work Ben!!!--------Jose R. SotoApopka, FloridaRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Using motercycle chain links
Okay, let's see if I got this right. :-)1-The pulleys are in the center section.2-The cable has to come apart at or near the junction betweenthe center section and outer wing.3-The turnbuckles are on the horn down at your feet.So it appears to me you need one small opening ten totwelve inches outboard of the pulley.You make the connection six inches outboard of the pulleywhen the system is in neutral ( aileros flat ).You unhook the turnbuckle connection and pull the cableand connector down through the hole. Since the connection issix inches outboard and the hole is twelve inches then this places the connector below the wing by six inches. Easy toget at now, isn't it. :-)Once those two connections are undone then unhooking thetop connections at both horns allows you to pull the entiretop cable turnbuckle assembly out the inspection hole you've added in the middle of the center section far enoughto easily work on it.My kids don't call me Crowdad for nothin' !Clif ----- Original Message -----
Pietenpol-List: Re: From print to jig...how?
Subject: Pietenpol-List: Weight and balance questionGood people,I have not covered my plane yet, but it is almost fully assembled. I am trying to estimate the CG of the fabric and paint. I know the approximate weightof all this, but I need some guesses from you guys as far as what the "arm" is, when doing my W&B calculations. Please help. Thanks.Dan HelsperPoplar Grove, IL.**************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-Volkswagen-Je ... 0000000007 )________________________________________________________________________________Subject: Pietenpol-List: Re: From print to jig...how?
Original Posted By: "Rob Stapleton, Jr."
I am in the process of building my Corvair 110 and soon to start on the Piet, wherecan I learn more about the Riblett airfoil and where can I obtain the drawing?Thank you all for all of your help, Joser.--------Jose R. SotoApopka, FloridaRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: From print to jig...how?
Jose,How is the Corvair engine project going? What exactly did you do to theengine? Did you follow William Wyne's manuals? I am curious here in Alaskaaobut what I need to do the additional engine project---I am also building aPiet with Corvair.As for the Riblett airfoil I can't help...I am using the traditionalPietenpol airfoil.Regards,RobRob Stapleton, PhotojournalistAnchorage, Alaska907-230-9425KL2ANSkype:rob.stapleton.jrIM Windows Live Messenger: foto(at)alaska.net-----Original Message-----
RE: Pietenpol-List: Re: My Piet has wings!
Yes, nice--but pretty hefty looking struts..actually a good idea for settingthe wing in place.RSRob Stapleton, PhotojournalistAnchorage, Alaska907-230-9425KL2ANSkype:rob.stapleton.jrIM Windows Live Messenger: foto(at)alaska.net-----Original Message-----
Hi Rob, after speaking at length with scores of builders, I will build my corvairstrictly to WW's manual and recommendations. I have read many articles involvingthe Corvair conversion and without a doubt no one is better qualified thanWW. I have disassembled the engine and will clean, powdercoat, paint and assemblewith a nitrided crank, the recommended cam and all of the gold productsthat WW offers. Will post pictures as I complete the work, hope to see your projectsoon, right now I am preparing for a major storm, later, Joser.--------Jose R. SotoApopka, FloridaRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 18 Aug 2008 10:29:07 -0600
Original Posted By: Roman Bukolt
Rick, I need the 100hp because I am 6'2" 260# Hahahaha. I have used this opportunityto remove the weight from the body, I was over three hundred at the beginningof the year! So I am on the Pietenpol lifestyle plan!--------Jose R. SotoApopka, FloridaRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Check the archives for info on the Riblett airfoil, in particular emails from Pieti Lowell.The prints are available from me for $10.00.Roman Bukolt6505 Urich TerraceMadison, Wi. 53719On Aug 18, 2008, at 8:25 AM, Joser wrote:>> I am in the process of building my Corvair 110 and soon to start on > the Piet, where can I learn more about the Riblett airfoil and where > can I obtain the drawing? Thank you all for all of your help, Joser.>> --------> Jose R. Soto> Apopka, Florida>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: From print to jig...how?
Original Posted By: "walt"
Hi Roman, I need two copies, how do I pay you? jsoto5(at)cfl.rr.comThanks, Joser.--------Jose R. SotoApopka, FloridaRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 18 Aug 2008 16:15:04 -0400
Just send a check $20On Aug 18, 2008, at 2:42 PM, Joser wrote:>> Hi Roman, I need two copies, how do I pay you? jsoto5(at)cfl.rr.com> Thanks, Joser.>> --------> Jose R. Soto> Apopka, Florida>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: From print to jig...how?
10-4--------Jose R. SotoApopka, FloridaRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 18 Aug 2008 19:34:40 -0400
Pietenpol-List: Re: Weight and balance question
________________________________________________________________________________Subject: Pietenpol-List: Re: Weight and balance question
Original Posted By: Marc Davis
The Kansas City Dawn patrol website did have a great program that you could downloadand use too.forget the guy's name-Dick Starks maybe? anyway they have afine site you might want to checkout.RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
