Pietenpol-List: Rear seat install
Original Posted By: "walt"
CampersAre you glueing in the rear seat botom and back=2C or making them removable for access to the tail cone?Thanks Marc _________________________________________________________________Be the filmmaker you always wanted to be=97learn how to burn a DVD with Windows=AE.________________________________________________________________________________Date: Thu, 28 Aug 2008 04:09:36 -0400
Re: Pietenpol-List: Rear seat install
Subject: Re: Pietenpol-List: Rear seat installMarc,I glued in my rear seat back because I feel that it is an important structural member. The seat bottom on mine just sits there by itself from gravity.I have a couple of pulleys under there that I need to get to. Photo attached. Dan HelsperPoplar Grove, IL.**************It's only a deal if it's where you want to go. Find your travel deal here. (http://information.travel.aol.com/deals ... 0000000047)________________________________________________________________________________Subject: Re: Pietenpol-List: Rear seat install
Original Posted By: Marc Davis
Glued the back and hinged the bottomJohn------Original Message------
Re: Pietenpol-List: Re: From print to jig...how?
RE: Pietenpol-List: Rear seat install
Yes I do.just send a check for $10.00 to:Roman Bukolt6505 Urich terraceMadison, Wi. 53719On Aug 27, 2008, at 11:37 PM, Allan Macklem wrote:> >>> Roman,>> Do you have the print for the GA3OU 612 airfoil?>> Allan>>________________________________________________________________________________
The rear seat bottom on 41CC is removable (lifts out) and the seat back is hinged.It's essential that you have access to the elevator bellcrank behind theseat, if nothing else.Oscar ZunigaAir Camper NX41CCSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
Subject: Re: Pietenpol-List: Rear seat installOn mine, in order to access the elevator bellcrank etc. I have installed a removable aluminum panel on the underside of the airplane held on with machinescrews and T nuts. I can actually get my whole upper torso in there with shoulders. Dan HelsperPoplar Grove, IL.**************It's only a deal if it's where you want to go. Find your travel deal here. (http://information.travel.aol.com/deals ... 0000000047)________________________________________________________________________________
That's always the best way. I find it very painful and inconvenient toremove my shoulders from my upper torso.(just in case it's not obvious, that's a weak attempt at a humorous comment) _____ Subject: Re: Pietenpol-List: Rear seat installI can actually get my whole upper torso in there with shoulders. Dan HelsperPoplar Grove, IL.________________________________________________________________________________Subject: RE: Pietenpol-List: Rear seat installDate: Thu, 28 Aug 2008 09:08:54 -0400
Pietenpol-List: Re: Rear seat install
Dan/anyone-I like that seat with the insert.is there any place that sells themat an affordable price? I have been looking for something that would look rightin a Piet and that is it for sure.RaymondRead this topic online here:http://forums.matronics.com/viewtopic.php?p 1317#201317________________________________________________________________________________
Thanks for all the input on how your doing your rear seats. Has anyone made the turtle deck removable to allow access to the tail cone?Seems easy enough. Marc _________________________________________________________________See what people are saying about Windows Live. Check out featured posts.http://www.windowslive.com/connect?ocid ... ___Subject: Re: Pietenpol-List: Rear seat install
Sounds easy enough actually building the turtle deck was one of the more difficultand time consuming assemblies to build. Making it removable would add anotherdimension of difficult. This of course is both the experience and opinion of a non experienced and Annettafledgling wood worker. I am certain you will get differing opinions from thosebetter and more talented than I. John------Original Message------
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________________________________________________________________________________Subject: RE: Pietenpol-List: Rear seat installDate: Fri, 29 Aug 2008 10:41:52 -0400
RE: Pietenpol-List: Access panel for horiz stab hold-down nuts
