Pietenpol-List: Corvair serial number
Original Posted By: "Patrick Panzera"
I am in the middle of Kansas on a job-just got my registration packet in and wantedto get the application sent off this week.but my engine is back home in Texas.doesa Corvair engine have an individual serial number and if so where isit located? I may be able to get my neighbor to go by the shop and get it forme.thanks for any help.RaymondRead this topic online here:http://forums.matronics.com/viewtopic.php?p 3201#203201________________________________________________________________________________
RE: Pietenpol-List: Corvair serial number
This might help:http://www.angelfire.com/ca4/CorvAIRCRA ... eID.htmPat> I am in the middle of Kansas on a job-just got my registration packet in> and wanted to get the application sent off this week.but my engine is back> home in Texas.does a Corvair engine have an individual serial number and> if so where is it located? I may be able to get my neighbor to go by the> shop and get it for me.thanks for any help.Raymond________________________________________________________________________________
Pietenpol-List: Re: Corvair serial number
Just picked up a copy of the Jackson sun newspaper out of Jackson, Tennessee. There on the FRONT PAGE is a story and photos of Randy and his Piet.. Go to jacksonsun.com to read the story and view the photos. Outstanding job Randy. I'm really pleased you have received the recognition you deserve. You make us all proud.GeneN502R ________________________________________________________________________________Subject: Pietenpol-List: Re: Corvair serial number
thank you pat as I understand your reply and Oscar's e-mail, the engines do nothave a serial number as such but simply a case code.and I am just as well toassign it a serial number of my choosing and stamp it on the case and move onwith the registration. i do appreciate you're taking the time to reply.RaymondRead this topic online here:http://forums.matronics.com/viewtopic.php?p 3297#203297________________________________________________________________________________
RE: Pietenpol-List: Re: Corvair serial number
Original Posted By: Jonathan Ragle
> thank you pat as I understand your reply and Oscar's e-mail, the engines> do not have a serial number as such but simply a case code.Raymond,The website I pointed out is devoted to the case code as well as the headcodes and NOT the serial number or VIN.Go back and check it out; it not only shows where specifically to find therelevant numbers but also what the numbers signify.The case code however is really only relevant in order to find out if theengine is a long or short stroke. Everything else that one needs to know iscast into the heads.As an example, you can have a case code that says it's a 95 or 110, butsomeone could have put 140 or even 180 heads on it well after it left thefactory so the case code doesn't tell the whole story. Pat________________________________________________________________________________
