Pietenpol-List: Spar on 3 piece wing plan
RE: Pietenpol-List: Re: Motorcycle master links
Original Posted By:> Bill Church
Actually there are, go to a farm machinery dealer, I can't tell you whattype of machinery, but I do know they exist. Also check out some Half links, Ibet there are some uses them as well.--- On Wed, 9/10/08, Bill Church wrote:
Re: Pietenpol-List: Brodhead 2009
We are desperately trying to get the 6 - Big Piets ready to fly up to Brodhead 09. Our goal was to hit the anniversary. We are in the covering wings stage. Sounds like a party to me!Barry Davis ----- Original Message -----
Original Posted By: Barry Davis
I'm trying my best to make it!!!Gene ----- Original Message -----
RE: Pietenpol-List: Brodhead 2009
Subject: RE: Pietenpol-List: Brodhead 2009My brother Andrew and I are planning to be there with the Pietenpol and Stinson. Watch for the twin "E"'sSteve E
RE: Pietenpol-List: Spar on 3 piece wing plan
Subject: Re: Pietenpol-List: Brodhead 2009If I work really hard, fast, diligently and without delays for divorce, I think I could make the 85th with ya Jack!JohnIn a message dated 9/10/2008 2:08:27 P.M. Eastern Daylight Time, jtextor(at)thepalmergroup.com writes:--> Pietenpol-List message posted by: "Jack T. Textor" Boy, I sure wish mine was going to be ready, but I will be there inspirit. Maybe the 85th!Jackwww.textors.com**************Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. (http://www.stylelist.com/trends?ncid=ao ... 0000000014)________________________________________________________________________________Subject: RE: Pietenpol-List: Spar on 3 piece wing planDate: Wed, 10 Sep 2008 13:33:43 -0500
> Dick,> > I don't think there is such a thing as a cotter pin> master link. But there> are drilled AN393 clevis pins. You will need to determine> the length you> need, based on the application you have.> Get some #50 roller chain (this chain has pins that are on> 5/8" centers) ,> and disassemble the chain into little bits. The only part> you will want is> the flat outer links (these are about 0.08" thick).> These links have holes> that are 0.20" diameter. The clevis pins are> 0.19" diameter, which will> result in a nice loose (non-binding) fit. Then get some #10> flat washers and> some 1/16" cotter pins, and put them together as shown> in the attached> image.> > Bill C. =0A=0A=0A ________________________________________________________________________________
