Can someone give me Jack Phillip's contact info. - I seem to have misplaced itand his full e-mail address doesn't show up when he posts.Thanks.--------Location: Eastern N.C.Read this topic online here:http://forums.matronics.com/viewtopic.php?p 8732#208732________________________________________________________________________________
Pietenpol-List: Jack Phillips - contact info?
RE: Pietenpol-List: Jack Phillips - contact info?
Pietenpol-List: Re: Jack Phillips - contact info?
Original Posted By: "Tom Anderson"
Subject: Re: Pietenpol-List: What does it REALLY cost to build and operate a Piet?In a message dated 10/14/2008 3:14:40 P.M. Eastern Daylight Time, AMsafetyC(at)aol.com writes:I am powering with an )235 108 hp Lycoming which has a major not more then 600 hours ago so all I need is to have the crank checked then its on to reassembly with gaskets, hoses and replacement of consumables and or questionableswhich who knows what that will costJohn John, hope your luck is better than mine. I have a 475SMOH 320 for another project. Sent it for prop strike inspection. That went fine except thatit needed turning. So $648 for machine work, and now I'll spend another $1300 or so on parts to reassemble as two of my drive gears are bad. Just can't winsometimes!Boyce________________________________________________________________________________Subject: Pietenpol-List: Re: Jack Phillips - contact info?
Thanks, Jack.--------Location: Eastern N.C.Read this topic online here:http://forums.matronics.com/viewtopic.php?p 8776#208776________________________________________________________________________________
Subject: Re: Pietenpol-List: What does it REALLY cost to build and operate a Piet?Boyce,Mine was a prop strike buy also, reported as minimal, I am not taking chances with crank issues on that. Visual by an A&P suggested it was probablyin good shape to the guy I purchased it from, checked run out all was reported ingood shape. Having been burned before on seemingly great deals I am having itinspected by a shop that can magnaflux it and give me an accurate read on the wear and life. just something about flying a piece of junk I don't want to be flying it when it reaches its full life potential of becoming a boat anchor....better to be alive and broke than dead and broke, I think?JohnIn a message dated 10/14/2008 3:27:33 P.M. Eastern Daylight Time, RAMPEYBOY(at)aol.com writes:In a message dated 10/14/2008 3:14:40 P.M. Eastern Daylight Time, AMsafetyC(at)aol.com writes:I am powering with an )235 108 hp Lycoming which has a major not more then 600 hours ago so all I need is to have the crank checked then its on to reassembly with gaskets, hoses and replacement of consumables and or questionableswhich who knows what that will costJohn John, hope your luck is better than mine. I have a 475SMOH 320 for another project. Sent it for prop strike inspection. That went fine except thatit needed turning. So $648 for machine work, and now I'll spend another $1300 or so on parts to reassemble as two of my drive gears are bad. Just can't winsometimes!Boyce(http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) **************New MapQuest Local shows what's happening at your destination. Dining, Movies, Events, News & more. Try it out (http://local.mapquest.com/?ncid=emlcntnew00000002)________________________________________________________________________________Date: Tue, 14 Oct 2008 12:37:45 -0700 (PDT)
