Pietenpol-List: inter-rib lacing tape or this ?
Re: Pietenpol-List: inter-rib lacing tape or this ?
Original Posted By: Cuy, Michael D. (GRC-RXD0)[ASRC]
inter-rib lacing tape or this ?Michael, I did the same as you with no problem taughtening and covering. Just don't forget the braces on the butt rib. I did, and I had to go in and add strips top and bottom for two spaces between the aft spar and the trailing edge. I am covered and primed now but the inside of the wing doesn't look near as nice as yours since I painted everything with grey epoxy primer. That is what I had in stock. Cheers, Gardiner Mason ----- Original Message -----
RE: Pietenpol-List: inter-rib lacing tape or this ?
I used the age old inter-rib lacing tape. My ribs did not move.Jack PhillipsNX899JP _____
