Pietenpol-List: eyebrow baffles
Original Posted By: "walt"
Subject: Pietenpol-List: eyebrow bafflesHi Rick, I cut an opening about an inch and a half or two inches wide the length of the area over the plugs and then made a plate slightly larger than the opening and put some baffling material under it to seal it and then just attachit with a sheet metal screw and tinnerman nut on each end. works great and easy access to the plugs. Randy Bush NX294RB**************New year...new news. Be the first to know what is making ________________________________________________________________________________Date: Sun, 04 Jan 2009 19:45:46 -0500
