Pietenpol-List: Mid-Wing Pietenpol
Re: Pietenpol-List: Mid-Wing Pietenpol
To: Subject: Pietenpol-List: MILESTONE!!! Attached is a (small) picture of what started out this morning as a flatpiece of aluminum...this building process is FUN! jm ~r________________________________________________________________________________Date: Mon, 23 Feb 2009 10:38:50 -0700Subject: Re: Pietenpol-List: Mid-Wing Pietenpol
I have a question gents!I have seen the "Biplane Piet, Mono-wing Piet,but.... has anyone ever seena Mid-Wing Piet????Also has anyone shortened the cabanes for a more "sporty" look...... (201/4 and 21 1/4" stock height) I know many people have made them longer foreasier access to the cockpit.....(spent an hour making shims for the elev. bellcrank.... looked at the plansand saw I had it on the worng side of the vert. brace....DAMM!!!!!)Cheers!Dave In Drizzley Ca. -----Original Message-----
Pietenpol-List: Re: Mid-Wing Pietenpol
Original Posted By: "Mild Bill"
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________________________________________________________________________________Subject: Pietenpol-List: Re: Mid-Wing Pietenpol
Re: Pietenpol-List: Re Tail dimensions
Great minds think alike. We won't mention the otherhalf of that saying, will we. :-)As you can see I'm using pins instead of bolts.Clif ----- Original Message -----
Well, I've seen a horse fly, and I've seen a house fly, and I've even seen a low-wingPietenpol, or at least a picture thereof:http://forums.matronics.com/viewtopic.php?t=41853So a mid-wing Pietenpol seems eminently possible. [Wink]--------Bill FrankRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Re: Mid-Wing Pietenpol
Heath did it.> Well, I've seen a horse fly, and I've seen a house fly, and I've even seen > a low-wing Pietenpol, or at least a picture thereof:> So a mid-wing Pietenpol seems eminently possible. [Wink]>> --------> Bill Frank________________________________________________________________________________
Re: Pietenpol-List: Elevator cable feel and tension trouble.
Original Posted By: Scott Schreiber
Scott, Almost sounds like you are having something hanging up. Pulley??Gene ----- Original Message -----
l-list(at)matronics.com>=0A Pietenpol-List: MILESTONE!!!=0A=0AAttached
l-list(at)matronics.com>=0ASubject: Pietenpol-List: MILESTONE!!!=0A=0AAttached is a (small) picture of what started out this morning as a flat piece of aluminum...this building-process is FUN!=0A-=0Ajm~=B2 r=0A=0A=0A" target="_blank">http://www.matronics.com/Navigator?Piet ... __________
