Pietenpol-List: Multi-master tool knock-off
RE: Pietenpol-List: Multi-master tool knock-off
Subject: Re: Pietenpol-List: Multi-master tool knock-offSo far the canard list guys are giving it a fairly favorable nod though the general consensus is that anything HF makes with an electric motor is suspect. We've had mixed results in that respect....Chrissi & RandiCG Products, Custom Aircraft Hardwarewww.CozyGirrrl.com Cozy Mk-IV RG 13B-turboPlans #957 Chapter? big pieces done, details, details=============================== In a message dated 3/2/2009 12:49:42 P.M. Central Standard Time, helspersew(at)aol.com writes:I just received my Harbor Freight sales flyer. They now sell a Multi-master knock-off for $39.99 (on sale) including 4 attachements!!! I don't know if it is any good, but for that price I am going to give it a try.Dan Helsper(http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) ________________________________________________________________________________Subject: RE: Pietenpol-List: Multi-master tool knock-offDate: Mon, 2 Mar 2009 15:01:47 -0500
Original Posted By: CozyGirrrl(at)aol.com
Bought one three days ago. Works good so farTim White ----- Original Message -----
What is this tool? Can you describe it?walt evansNX140DL ----- Original Message -----
Yes I'd like to hear more too, I looked up Multi-master on their websiteand it didn't bring up anything.BrianSLC
Original Posted By: Ameet Savant
Original Posted By: "Ameet Savant"
So is this like a nibbler?walt evansNX140DL----- Original Message -----
I have 2 of the Fein Multimasters. They are the cats meow! You can saw a square corner with them, cut the grout out of your floor to replace it in a very short time, and cut off door jambs. They can sand in tight areas, like corners. They are used to remove windshields and silicone seal too. The only drawback to the Fein tools is the blade cost is just unbelievable,...$ 40 - $ 50 each blade with some even more. For the cost of one Fein blade you can buy the whole Harbor Freight unit. I have seen other companies that make them also, but I can't remember the brands off hand. They use the old style of blade attachment that Fein formerly used, a screw. Still they cost way less than the new type of Fein. The motor turns a cam which is straddled by a V shaped yoke. The blade attaches where the legs come together on the V.dennis
Original Posted By: Dennis Engelkenjohn
But what does it do???Is it like a nibbler????walt evansNX140DL ----- Original Message -----
Subject: Pietenpol-List: HR 4-1 toolRockwell makes a tool called the Rockwell SoniCrafter that work on the same principal as the Fein.I bought the SoniCrafter thru Amazon.com.It is cheaperthan the Fein but it is heavy duty. I just ordered 3 blades for $39 plus shipping. So far I am very satisfied with it. I paid $139 for mine with the parts I wanted with it.It will do all they say it will do.I was going to try theHF one but they seem to have it in stock. Maybe you will have better luck.Ted Stonebuilding a Corvair Piet**************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! %3D62%26bcd%3DfebemailfooterNO62)________________________________________________________________________________Subject: RE: Pietenpol-List: Multi-master tool knock-offDate: Mon, 2 Mar 2009 18:19:47 -0500
Original Posted By:> Dennis Engelkenjohn
No it isn't a nibbler. With the sawblade it is kind of like a cast cutter. The multimaster is great at clean, deep cuts in all sorts of material. I use mine for clean cuts in fiberglass which tend to dull out regular blades very quickly. The oscillating action is also good for sanding in very tight spaces and for grinding out material like tile grout. I bought mine for the fiberglass work but end up using it all the time on other projects.On Mar 2, 2009, at 2:58 PM, "walt" wrote:> But what does it do???> Is it like a nibbler????> walt evans> NX140DL>>> ----- Original Message -----
Original Posted By:> helspersew(at)aol.com
Check outhttp://www.moto.aero/index.php?option=com_cont ... rcesKirkOn Mar 2, 2009, at 4:45 PM, Dennis Engelkenjohn wrote:> I have 2 of the Fein Multimasters. They are the cats meow! You can > saw a square corner with them, cut the grout out of your floor to > replace it in a very short time, and cut off door jambs. They can > sand in tight areas, like corners. They are used to remove > windshields and silicone seal too.> The only drawback to the Fein tools is the blade cost is just > unbelievable,...$ 40 - $ 50 each blade with some even more.> For the cost of one Fein blade you can buy the whole Harbor > Freight unit.> I have seen other companies that make them also, but I can't > remember the brands off hand. They use the old style of blade > attachment that Fein formerly used, a screw. Still they cost way > less than the new type of Fein.> The motor turns a cam which is straddled by a V shaped yoke. The > blade attaches where the legs come together on the V.> dennis
Original Posted By: _helspersew(at)aol.com_ (mailto:helspersew(at)aol.com)
Subject: Re: Pietenpol-List: Multi-master tool knock-offIt is like a cast cutter in the hospital, I've demo'd one by shoving the tool while running into my own face (do not do this with a brand new blade (until the burrs get worn off) ask me how I know) Only cuts stationary materials.Anyhow, cuts hardwoods, composites, plastics etc. kerf is micro thin, no spinning blade to catch. This is NOT a detail sander like the Ryobi junk.Even at $250 they were a deal, we would not build a composite aircraft without one....ChrissiCG Products, Custom Aircraft Hardwarewww.CozyGirrrl.com Cozy Mk-IV RG 13B-turboPlans #957 Chapter? big pieces done, details, details==============================If you have a "Spam Blocker" that requires we fill out a form you will not hear from us.Please do not make your spam problem ours. In a message dated 3/2/2009 2:56:37 P.M. Central Standard Time, waltdak(at)verizon.net writes:What is this tool? Can you describe it?walt evansNX140DL----- Original Message -----
> Yes I'd like to hear more too, I looked up Multi-master> on their website> and it didn't bring up anything.> > > > Brian> > SLC> > >
Original Posted By:>> owner-pietenpol-list-server(at)matronics.com
>> Yes I'd like to hear more too, I looked up Multi-master>> on their website>> and it didn't bring up anything.>>>>>>>> Brian>>>> SLC>>>>>>
