Pietenpol-List: Straight axel again
A guy could probably get creative and make this thing work. Just have to comeup with a way to attach a Stainless Steel welding rod through the bore of it.I suppose you could solder a thin piece top and bottom and run the rod throughit and solder. http://www1.mscdirect.com/CGI/NNSRIT?PM ... =61847625I used a big fat magic marker body for mine. I pulled all of the ink soaked feltout of it, turned up a small fitting on the lathe for the end of it, drilledand tapped it for my 3/32" threaded welding rod and then welded that onto themarker body. Just some ideas.Don EmchNX899DERead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Straight axel again
Original Posted By: "Lagowski Morrow"
I have a gear mock up now built. Would anyone mind sending me pics of their axel to gear mounting in detail of thetraditional system in addition to any non bungee designsThanksHappy holidayJohnSent from my Verizon Wireless BlackBerry________________________________________________________________________________
Re: Pietenpol-List: Straight axel again
John, I used Fly Baby gear which has no bungees and a single axle, wire braced. Fat, low pressure tires are the Shock absorber. I did so because of Kyle Bradford in Eaton Rapids Mich. who used the same on his many year old Piet. When I looked at his plane I liked the simplicity of it and copied it. He sent me a copy of a Pete Bowers article which shows how to build the gear. Bowers is/was Mr. Flybaby. I'll send you (or others) a copy of what Kyle sent me. It is from an article datedMay 1963.--Jim Lagowski in N.W. Michigan----- Original Message -----
Original Posted By: Lagowski Morrow
That would be great please forward for reviewThanksJohn------Original Message------
John, send me your mailing address, since it will have to be by mail--Jim----- Original Message -----
Subject: Re: Pietenpol-List: Straight axel againJim,Thanks for getting back to me.Please send to John Recine 635 South Broad StreetLititz, PA 17543ThanksJohn**************The Average US Credit Score is 692. See Yours in Just 2 Easy Steps! mpgID%3D62%26bcd%3DAprilAvgfooterNO62)________________________________________________________________________________
It's in the mail-Jim ----- Original Message -----
Original Posted By: Woodflier(at)aol.com
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________________________________________________________________________________
I would sure appreciate a copy, if it is possible. I have the plans and most of the wood and parts, including ribs completed. Will start building this fall. I will pay the cost for copying and sending, etc.Thanks,Ray Krause843 Jay StreetColusa, CA 95932530-458-7097----- Original Message -----
Re: Pietenpol-List: Rib lacing on tail feathers
RE: Pietenpol-List: Rib lacing on tail feathers
Matt, 2-1/2" is the recommended spacing in the propwash unless your VNE isgreater than 175 mph. If you keep the rib-lacing as done, you will have tolimit your Piet to speeds less than 175. It is conceivable that the tailcould see such speeds, after the wings have been shed in a terminal velocitydive.Incidentally, I used the 2-1/2" spacing on my entire wing, just to make iteasier. It only added a couple of extra stitches per rib.Jack PhillipsNX899JP _____
Matt, I used 2 1/2" spacing in the prop wash area per the diagram in the Polyfiber manual, and then decided to use 2 1/2" everywhere for uniform appearance--Jim Lagowski ----- Original Message -----
